Re: Friends truck died need some tech help please
[Re: therocks]
#866750
12/04/10 06:57 PM
12/04/10 06:57 PM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
If its a tilt its down there on the base of the column but if its a standard non-tilt then its inside the column, hence the wire suggestion. In '88 they went to a rod style but his '85 should have the switch in the column if its a non-tilt.
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
