Re: Speedo cable - where does it run [Re: cudaized] #866432
12/03/10 05:12 AM
12/03/10 05:12 AM
Switzerland, Europe
Swiss_Robert Offline OP
Switzerland, Europe
Great, thank you!
No idea who sells that clip.
It's the first time, I see how this linkage looks - the one that locks the ignition key over the "shifting tube" when there is a manual transmission. I assume that thing is often absent - as it is in my car...
After all these years having a 440 I realized that this means having an attitude... and a budget.
Re: Speedo cable - where does it run [Re: cudaized] #866433
12/03/10 09:32 AM
12/03/10 09:32 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Next.
BTW: Does anyone know who sells these speedometer cable - to - frame rail metal clips?
Maybe Tom at R/T?
Yep
http://www.rtspecialties.net/proddetail.asp?prod=1000092
Re: Speedo cable - where does it run [Re: Swiss_Robert] #866434
12/03/10 10:17 AM
12/03/10 10:17 AM
South, FL
cudaized Offline
cudaized  Offline
South, FL
You are indeed correct.
A lot are missing. Who wants to put the car in reverse, just to get the key out. A pain in the @ss if you ask me. Especially if your A833 is a little worn out and is hard to get in reverse. Or those straight cut gears are not lined up exactly.
There are originals for sale (usually not complete) and also reproductions.
Re: Speedo cable - where does it run [Re: gtx6970] #866435
12/03/10 10:18 AM
12/03/10 10:18 AM
South, FL
cudaized Offline
cudaized  Offline
South, FL
Re: Speedo cable - where does it run [Re: cudaized] #866436
12/03/10 08:53 PM
12/03/10 08:53 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Wow - Never seen those frame rail clips on E-Bodies - Only B-Bodies. I don't believe any of my cars have ever had them. Time for a closer look.
I think Chrysler still sells them - haven't checked in a while.
Re: Speedo cable - where does it run [Re: FJ5_Fish] #866437
12/03/10 10:48 PM
12/03/10 10:48 PM
Ont, Canada
moparo Offline
moparo  Offline
Ont, Canada
I have those clips
I also have seen the same whitish looms which hold the wiper hose to the fire wall on the passenger side on an e-body.
performancecarrestorations.com
Re: Speedo cable - where does it run [Re: moparo] #866438
12/03/10 10:52 PM
12/03/10 10:52 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
I have those clips
When you say you have those clips - do have them on an E-Body or you have them in your pocket trying to use them at Tim Horton's?
Yes - A couple of mine have the white straps too.
Here is where it broke off....
Re: Speedo cable - where does it run [Re: FJ5_Fish] #866439
12/03/10 10:59 PM
12/03/10 10:59 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
And here is the rest...
Re: Speedo cable - where does it run [Re: FJ5_Fish] #866440
12/03/10 11:39 PM
12/03/10 11:39 PM
It's a dry heat
It's a dry heat
Jim.
My old 70 challenger 340 had one and the current 70 cuda I'm working on now has one
Re: Speedo cable - where does it run [Re: FJ5_Fish] #866441
12/03/10 11:46 PM
12/03/10 11:46 PM
Ont, Canada
moparo Offline
moparo  Offline
Ont, Canada
No not my pocket but in a bin.
Re: Speedo cable - where does it run [Re: gtx6970] #866442
12/03/10 11:59 PM
12/03/10 11:59 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Thanks - When / where were they built Bill? How weird is it that my E-bodies have the plastic strap? Where's Rod Serling?
Re: Speedo cable - where does it run [Re: FJ5_Fish] #866443
12/04/10 12:07 AM
12/04/10 12:07 AM
Ont, Canada
moparo Offline
moparo  Offline
Ont, Canada
I think it might be a plant thing.
Re: Speedo cable - where does it run [Re: FJ5_Fish] #866444
12/04/10 12:10 AM
12/04/10 12:10 AM
Ont, Canada
moparo Offline
moparo  Offline
Ont, Canada
The picture of the car with clip is a convert.
Check your ebody convert Jim
Re: Speedo cable - where does it run [Re: moparo] #866445
12/04/10 10:25 AM
12/04/10 10:25 AM
South, FL
cudaized Offline
cudaized  Offline
South, FL
The car with the clip is a `cuda340 3 speed hard top built at Hamtramck SPD 203 that had 34,000 original miles when I purchased it.
It was almost all original.
Re: Speedo cable - where does it run [Re: cudaized] #866446
12/04/10 10:50 AM
12/04/10 10:50 AM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Yes - It looks like a good car! All the stuff is still there and looks in great shape.
Re: Speedo cable - where does it run [Re: cudaized] #866447
12/04/10 02:58 PM
12/04/10 02:58 PM
Ont, Canada
moparo Offline
moparo  Offline
Ont, Canada
Well that shoots that out the window.
