440 Intake removal #865593
11/28/10 01:04 PM
11/28/10 01:04 PM
CA
mojavered Offline OP
CA
I want to try an intake swap. I am running the EZ heads and using the Indy valley plate. When I pull the intake, do I need to worry about that valley plate? Will I need to add any new sealant or anything? Just want to make sure I have everything when I do this. Thanks.
71 Challenger RT
440 / 727 / 8.75
Re: 440 Intake removal [Re: mojavered] #865594
11/28/10 01:07 PM
11/28/10 01:07 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The valley plate is under the heads so it won't be disturbed , a new set of intake gasket would probably be a good idea though.
Re: 440 Intake removal [Re: JohnRR] #865595
11/28/10 01:09 PM
11/28/10 01:09 PM
CA
CA
Perfect, that is what I was hoping for. Thanks!
71 Challenger RT
440 / 727 / 8.75
