Dakota Defrost Fan Not Working #86526
07/09/08 09:43 PM
07/09/08 09:43 PM
NY
old340dog Offline OP
NY
I've got a 2004 Dakota Quad cab,V-8, 4x4. All the sudden my defrost fan switch for heat/AC isn't working.Any idea where to look to find the problem? Seems like I've seen posts with this problem a while back. It's a pain not having AC.Any suggestions? I hate to take it to a dealer, if I can fix it myself.
old340dog
Re: Dakota Defrost Fan Not Working [Re: old340dog] #86527
07/09/08 09:47 PM
07/09/08 09:47 PM
Table Rock Lake Missouri
furious Offline
furious  Offline
If it is like my 90, there is a wirewound resistor network that controls the blower speed, very crudely. Should be easily removeable on firewall side with two sheet metall screws.
I do have a spare if you need it.
Re: Dakota Defrost Fan Not Working [Re: old340dog] #86528
07/09/08 10:18 PM
07/09/08 10:18 PM
PA
noplanb Offline
noplanb  Offline
PA
Your blower resistor pack is fried. I have the same truck and just had the same problem.
The replacement costs $11.85 from Ma (part # 5174618AA), look for a connector between two 8mm screws under the glovebox, unscrew, take out the old pack, plug in the new one. Super easy fix the dealer would charge you $200 to do.
remember when you said honey, some day that car is gonna look so good in front of our house
Re: Dakota Defrost Fan Not Working [Re: noplanb] #86529
07/10/08 09:55 PM
07/10/08 09:55 PM
NY
NY
Thanks for the info guys. Stopped by Mopar Dealer today after work and picked the part up. got home home installed it 15 minutes later my fan was working.
old340dog
