First put the lightest advance springs in set total to 38 and see what it gives for idle when all set up.
I use the lightest springs with the smallest stops (most deg of advance allowed) to get good idle but ease of starting.
I even go as far as to use mopar or Mr gasket mopar springs which are lighter again than MSD's lightest on bigger cams to have it all in by 1200 to 1500.
after putting the lightest springs in try for an in gear idle of 900 to 1000 with that cam big cams like faster idle.
Set the valves .010 intake and .014 exhaust cold as the aluminum heads open the lash up as it warms up!
