Re: Trans temp gauge
[Re: crlush]
#863521
11/25/10 08:53 PM
11/25/10 08:53 PM
Posts: 12,295 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The pan is the best place to put it. But I often just get a brass T and put it in the line that goes to the cooler. For average temps it will be about the same as the pan. But it will show a higher temp when loading the tranny heavier.
Just cut the tranny line, put the T in with the temp sender. You will need to run a small wire from the T to a ground in order for the guage to read.
Master, again and still
[Re: POZEST]
#863524
11/25/10 11:41 PM
11/25/10 11:41 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I have mine just outside the out on the tranny. I just went to the local ace hardware and pieced together a brass fitting T that I put the sending unit into.
