Re: 64 273 question
[Re: 68cuda360]
#862279
11/24/10 08:35 AM
11/24/10 08:35 AM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
I did a '65 273 by changing to a Comp hydraulic cam and kit and using later 318 LA pushrods, and rocker setup. Works just fine.
This is the land of the free
because of the brave
Re: 64 273 question
[Re: 68cuda360]
#862282
11/24/10 10:36 PM
11/24/10 10:36 PM
Posts: 15,487 Florida
scratchnfotraction
IIRC 67 273 is non adjustable rockers and hydro lifters
the 64 is solid lifter cup and ball push rods adjustable rockers
could have a steel crank in both
64 may have closed chamberd heads with small valves
I think 65 is the oddball intake bolt pattern on the 273..1 yr only
Re: 64 273 question
[Re: scratchnfotraction]
#862289
11/25/10 03:07 AM
11/25/10 03:07 AM
Posts: 16,161 Mesa, Arizona
dart4forte
Mesa, Arizona
67 was still solid. 273 went to hyd cam starting in 68. Also, the Isky E4 is a good grind for the 273.
Re: 64 273 question
[Re: dart4forte]
#862290
11/25/10 11:16 AM
11/25/10 11:16 AM
scratchnfotraction
I was pretty sure I had a 67 with hydro non adjust rockers might have been worked on before I gots it ![](/ubbthreads/images/graemlins/shruggy.gif) what are the specs on that E4 grind? uncle had a 273 with a .500 lift something or other that was nasty in the 273,he siad 273 hipo but I thinks it was aftermarket with that lift ![](/ubbthreads/images/graemlins/shruggy.gif) I know they can be fast..just ask member "Class of 65" with a record holder 273 ![](/ubbthreads/images/graemlins/drive.gif)
Re: 64 273 question
#862292
11/25/10 01:58 PM
11/25/10 01:58 PM
Posts: 2,826 NY usa
540challenger
NY usa
There was a 273 Super command i think they called it from the factory .500 lift solid cam and a 750 holley very rare however
Re: 64 273 question
[Re: 540challenger]
#862294
11/25/10 09:30 PM
11/25/10 09:30 PM
dart4forte
Mesa, Arizona
You must be referring to the D/Dart
Re: 64 273 question
[Re: 68cuda360]
#862295
11/25/10 09:43 PM
11/25/10 09:43 PM
dart4forte
Mesa, Arizona
http://www.iskycams.com/onlinecatalog.htmlHere's a good 273 combo. Run a CR of 9.1 to 9.5 E4 Isky solid Cam Find a set of 920 casting heads (66-67). They flow the best. They flow better running a stainless 1.88 intake valve cut down to 1.82. That way there's no shrouding. If you can't find that casting 302's are a good alternative. Run a Edelbrock LD4B and a Carter 625. Of course a good ignition and exhaust. 273's make power as long as the RPMs are up. 273's like a lot of gear. For a street A body with a 273 3.91's are a good start.
