Page 2 of 3 1 2 3
Re: bet you never had this problem [Re: kingkt] #861493
11/24/10 04:04 AM
11/24/10 04:04 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
The pilot bearing on my car shrunk up a lot after the install.
I had to spend tall $$$ on the correct size reamer to resize it.
Re: bet you never had this problem [Re: MoparforLife] #861494
11/24/10 07:49 AM
11/24/10 07:49 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Cut about 1/8 inch off the transmission input shaft where it goes into the pilot. It is bottoming out in the crankshaft and binding up.
Bingo! I'll take the bet that this is what it is. Mine did the same thing. You can easily test if this is it by loosening the 4 trans to bellhousing bolts and try shifting it when it's running then. I had to grind off about 1/2 of an inch from the input shaft to get clearance. My crank just wasn't drilled deep enough, or the scatter shield was shorter from block to trans.
Re: bet you never had this problem [Re: kingkt] #861495
11/24/10 10:53 AM
11/24/10 10:53 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The only question not ask so far that I see,is the bell housing opening concentric with the crank shaft ? If not they make offset dowel's to correct the problem.
Re: bet you never had this problem [Re: kingkt] #861496
11/24/10 10:57 AM
11/24/10 10:57 AM
Jensen Beach, Florida
pressureangle Offline
Sounds like your clutch is dragging. Check for full disengagement, oil/grease contamination, or warpage.
Why do I torture myself so?
Re: bet you never had this problem [Re: 62maxwgn] #861497
11/24/10 11:00 AM
11/24/10 11:00 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Also what pilot bushing are you using ?
What is the engine?
Re: bet you never had this problem [Re: JohnRR] #861498
11/24/10 11:52 AM
11/24/10 11:52 AM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
i had a new pilot in the shop so i checked it on the shaft before installing it and it fit great. its a 383
Re: bet you never had this problem [Re: kingkt] #861499
11/24/10 12:06 PM
11/24/10 12:06 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If your'e using the stock style bushing it could be compressing when you press it into the crank. That would make for a really tight fit.
You couldn't get the transmission out of the car. That tells me the pilot pushing had a death grip on the shaft.
Forget all the other stuff for now. Measure the pilot bushing and the input shaft diameters. You will likely find the problem there.
Once you have that straightened out, fit the transmission without the clutch disc. See if the transmission is still too tight.
- Stu Harmon
Re: bet you never had this problem [Re: feets] #861500
11/24/10 12:11 PM
11/24/10 12:11 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
i agree but ive been thinking how do i make it fit properly?? do i drill out the pilot slightly. or do i use some emery cloth on the shaft?
Re: bet you never had this problem [Re: kingkt] #861501
11/24/10 12:14 PM
11/24/10 12:14 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You need to take the emory cloth to the bushing. It's MUCH softer than that hardened steel shaft.
- Stu Harmon
Re: bet you never had this problem [Re: feets] #861502
11/24/10 01:36 PM
11/24/10 01:36 PM
Alberta
rustbuckett68 Offline
Alberta
Was it an original manual trans car, engine, and crank? I seem to remeber that some AT cranks were not reamed to the correct pilot bushing size. IIRC the bushing should be a snug fit, no hammering.
Re: bet you never had this problem [Re: jbc426] #861503
11/24/10 02:08 PM
11/24/10 02:08 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
It's a quick & simple test. Loosen the four transmission bolts so there's about 1/3 of an inch gap between the trans and the bell housing, start it and and try shifting it into gear. I'll bet you it goes right into gear.
Re: bet you never had this problem [Re: rustbuckett68] #861504
11/24/10 05:08 PM
11/24/10 05:08 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
it is an original 4 speed cuda. it was a 340 4 speed and now 383 4 speed the crank had a original pilot in the crank and the new pilot went it ok i did need to press it in. i put the pilot in the freezer overnite before installing.. ive been working on it all day now and found that the new pilot shrunk the i.d. went it went in. also after measuring and remeasuring it seemed the shaft was bottoming out in the crank and there was some evidence of that on the end of the shaft where it was flat and the metal curved up very slightly. i took a new pilot bushing and slid it on the shaft and it fit loosely. then found a dowel that fit that pilot the same way as the shaft then tried to fit the dowel into the pilot installed in the crank and it was super tight. i then cut the shaft to acccomadate the crank. i ground the shaft where it was fatter at the end where it was past the bushing when installed. i used emery cloth on the shaft and bushing. now the dowel fits the installed bushing nicely. im having lunch and ill be stabbing the trans this afternoon. ill let all you helpful guys know what happens when i gitterdone . i thank all of you for your input!
Re: bet you never had this problem [Re: kingkt] #861505
11/24/10 06:54 PM
11/24/10 06:54 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
Sounds like you are on the right track, but know this: A new, uninstalled pilot is OVERSIZE ID. It is shrunk some amount when installed, so you cannot use a loose, uninstalled pilot for size comparison
Re: bet you never had this problem [Re: Yancy Derringer] #861506
11/24/10 07:51 PM
11/24/10 07:51 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
thats right.. i used the clutch alignment tool and saw that was tight in the installed pilot. then found a dowel that fit the same way on the tool. then used the dowel on the shaft for comparison. and then started using the emery cloth until the dowl and the shaft moved nicely. i just finished installing the bellhouse. and i have the tranny suspended and ready to stab.ill stab it in the next hour or 2 and let everyone know how i make out.its one of those thing that i know i better not rush.
Re: bet you never had this problem [Re: kingkt] #861507
11/25/10 02:15 AM
11/25/10 02:15 AM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
I have used the later style roller pilot bearings instead of the bronze bushings when installing the a-833. The roller bearings always fit the crank hub. If the crank hasn't been drilled you can use the roller bearing as a guide and drill the back of the crank, that way you don't have to hack off the end of the input shaft on the transmission.
http://www.brewersperformance.com/proddetail.asp?prod=PRB5300
Re: bet you never had this problem [Re: 440fied] #861508
11/25/10 10:25 PM
11/25/10 10:25 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
hey thats a great idea! looking at it i did not get it at first but it fits in the crank in front of the hole where the pilot bushing would go right?? so basically i would just remove the bushing in there now. i never got around to stabbing it yet being turkey day ill be back at it tomorrow unless i decide to go the bearing route
Re: bet you never had this problem [Re: kingkt] #861509
11/26/10 02:39 AM
11/26/10 02:39 AM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
Yep, it fits in the crank in front of the hole where the bronze pilot bushing goes. Just take out the bronze bushing and install the roller bearing flush with the end of the crank. No more worries about the input shaft seizing inside the bronze bushing.
Re: bet you never had this problem [Re: 440fied] #861510
11/26/10 10:25 AM
11/26/10 10:25 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I've seen the roller pilot bearing come apart, but never a bronze bushing.
Re: bet you never had this problem [Re: BSB67] #861511
11/26/10 11:51 AM
11/26/10 11:51 AM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
now that throws a monkey wrench in my thoughts
Re: bet you never had this problem [Re: kingkt] #861512
11/26/10 01:15 PM
11/26/10 01:15 PM
Muskegon Mi
dcr Offline
dcr  Offline
Muskegon Mi
Is this a scattershield you are useing or a stock bell housing?If its a scattershield did you check for proper runout?
Page 2 of 3 1 2 3
