Removing power steering box? #861150
11/23/10 01:12 AM
11/23/10 01:12 AM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Can it be done without removing the 440 from my Challenger? The steering box has been leaking all summer and I'm about it but not to the point that I would have to pull the motor I hope
Re: Removing power steering box? [Re: ccdave] #861151
11/23/10 01:25 AM
11/23/10 01:25 AM
Hemiroid Offline
Hemiroid  Offline
Yep, can be done with the engine in place. Just did it on my '68 GTX.
Re: Removing power steering box? [Re: ccdave] #861152
11/23/10 01:26 AM
11/23/10 01:26 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
The engine wont have to be removed. But the driver side engine mount and header may come into play for removal. But , the engine will not have to be removed. mike
Re: Removing power steering box? [Re: Sport440] #861153
11/23/10 01:36 AM
11/23/10 01:36 AM
Az
Crizila Offline
Crizila  Offline
Az
If it's the sector shaft seal you might try replacing it with the box in place.
Fastest 300
