Ok, this is about my 1985 D-150, but it is a general electronic ignition question. The wiring is totally hacked in this truck, so I'm just going to start fresh. It was originally a 225 lean burn, but now is a 318 with standard electronic ignition. My main question is: Should I use a 5 pin ecu with a 4 prong ballast, or a 4 pin ecu with a 2 prong ballast. I was told to do it either way, but to be careful if you use the 2 prong ballast as some of the other electronics on the truck may need to use the ballast as well. Which is better and why? I have a bunch of production 5 pin ecu's, but if a 4 pin would be better, that's what I'll do. This is a street vehicle, not a racer. Thanks!!
