burn off method #86038
07/08/08 08:27 PM
07/08/08 08:27 PM
Anonymous OP
Anonymous OP
Anybody have any info on the burn off method for removivg paint and stripping down a car?
Re: burn off method #86039
07/08/08 08:30 PM
07/08/08 08:30 PM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
Re: burn off method #86040
07/08/08 08:36 PM
07/08/08 08:36 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Heat can warp metal. Does not sound like a good idea to me
Re: burn off method #86041
07/08/08 09:00 PM
07/08/08 09:00 PM
Anonymous OP
Anonymous OP
you talkin about gel paint remover?
Re: burn off method #86042
07/08/08 09:33 PM
07/08/08 09:33 PM
Anonymous OP
Anonymous OP
From what I know the shell is actual put in an oven and the paint is turned to ash.
Re: burn off method #86043
07/08/08 09:48 PM
07/08/08 09:48 PM
IN
ahy Offline
ahy  Offline
IN
I've heard of doing pieces of cars with the burn off method. One example was a vintage air cleaner sheetmatal base. It was put in an oven to burn all the paint to ash then bead blasted to remove rust. Didn't harm the part at all.
I didn't know there were ovens big enough for a whole car. If it were heated gently and supported well it shouldn't hurt the shape of the metal.
Like tank dipping it would remove factory dip primer and sealers in hidden areas like frame rails. A lot of care would be meeded to get the dust out and replace the corrosion protection in the hidden spots.
Re: burn off method [Re: ahy] #86044
07/08/08 10:18 PM
07/08/08 10:18 PM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
There's a place south of Detroit, Michigan that I think can run a whole car in the oven. That gets the paint off and they give it an acid bath to eat the rust off. I've used them for fenders etc, but not a whole car. Works good for surface rustb but the cancerous type doesn't clean up real well. There.s a place in Toledo, Ohio that does the electrical stripping. 100% of all paint and rust removed without damaging the metal. They can do a whole car. I used to use this place but they got really $$$$$.
Re: burn off method [Re: 6pkaar] #86045
07/08/08 10:23 PM
07/08/08 10:23 PM
Anonymous OP
Anonymous OP
Thats the problem the place in Toledo has gottenvery expensive about $1800 for the shell.
Re: burn off method #86046
07/09/08 12:06 AM
07/09/08 12:06 AM
iowa
copchaser Offline
copchaser  Offline
iowa
I know of a small shop that does it. They claim that as long as they let it cool down evenly and slowly there will be no warpage. It has to be a controlled cool down.
Re: burn off method [Re: copchaser] #86047
07/09/08 01:51 AM
07/09/08 01:51 AM
dulcich Offline
dulcich  Offline
How about cooling it down with a garden hose, that way you can get in and work on it sooner.
Re: burn off method [Re: copchaser] #86048
07/09/08 02:20 AM
07/09/08 02:20 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
