Page 2 of 4 1 2 3 4
Re: CARB CHANGE EXPECTATIONS??!!! [Re: cudadon] #859315
11/22/10 03:36 PM
11/22/10 03:36 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
"OK you dirty rat!" LOL! Don..I'm checking into purchasing a ProForm/QuickFuel 1050 main body(4150)Sounds like a budget-friendly way to pick up a couple mph next season! My only concern is streetability...
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859316
11/22/10 03:53 PM
11/22/10 03:53 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Proform buys the Billet pieces (base plate, metering blocks) for their carbs from Quick Fuel & Quick Fuel buys the main bodies & float bowls from Proform. I got that info straight from a guy that works at Proform.
Re: CARB CHANGE EXPECTATIONS??!!! [Re: STEFF] #859317
11/22/10 04:45 PM
11/22/10 04:45 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks for clearing up ALL the confusion,Steff! What have you heard about these 1050 main bodies? Would it be an improvement over the air-horn removed 850DP that I'm currently using??? One would think with an extra 160-170cfm of airflow..it would pick up 2-3 mph! FWIW...I don't think it would degrade my low speed response much,if at all,running a 4:56 gear,and a Dynamic 9.5" 4600 stall converter.
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859318
11/22/10 04:54 PM
11/22/10 04:54 PM
STEFF Offline
STEFF  Offline
Not sure what it would do. I have a Proform 950 on my 6.1 Hemi & so far it seems to work well.
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859319
11/22/10 06:46 PM
11/22/10 06:46 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I want more air flow..without hurting streetability, If I can get a couple of mph,and still have low-speed throttle response...I'll be a happy camper!
Then get a TR & 2 carbs , i'm serious, if your looking for flow, i will say this, unless your carb is jacked up & has issues & not tuned right, your not going to see enough gain to justicy the exspence going with another single carb, your 850 flows alot, more then a 950, thats where some get confused, they look at the larger #, but its just a #, all a 950 is is a tricked out 750 with an 850 base, like mentioned earlier, it'll most likely give you better 60ft. times which will help ET, but if your wanting "flow" & MPH get a TR, i'm sure it'll 60ft. & ET better too. Then you'll be a VERY happy camper.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: CARB CHANGE EXPECTATIONS??!!! [Re: joedust451] #859320
11/22/10 09:23 PM
11/22/10 09:23 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Tunnel Ram?...no thank you! It's all I can do to tune one carb..let alone 2 of them! Joe,I'm seriously looking into purchasing a ProForm 1050 main body(4150-style)Supposedly,they actually flow 1050cfm,and bolt up to an 850 base..which I have! I have more research to do,though! I'd like to hear from more people who have tried them out!
Re: CARB CHANGE EXPECTATIONS??!!! [Re: joedust451] #859321
11/22/10 09:23 PM
11/22/10 09:23 PM
Benton, IL.
DaveRS23 Offline
Master of nothing...
DaveRS23  Offline
Benton, IL.
Why not just get a used Dominator and try it? You KNOW that they flow their rating. It is a shame that the cfm ratings on so many carbs are fiction.
Get a 1/2" adapter and a used Dominator (or better yet, borrow one) and see how it likes it.
Master, again and still
Re: CARB CHANGE EXPECTATIONS??!!! [Re: joedust451] #859322
11/22/10 09:30 PM
11/22/10 09:30 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Check out Dwayne Porters numbers http://www.moparts.org/Tech/Archive/bb/8.html
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859323
11/22/10 09:40 PM
11/22/10 09:40 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
on a stock stroke 440 based combo, especially in a heavy car, if i were to be inclined to use a downleg booster carb, i'd stick with something that had a 1.425-1.450 max venturi diameter.
going from memory here....
Mighty Demon 750 = 1.400
Mighty Demon 825 = 1.425
QFT Q-750 = 1.375
QFT Q-850 = 1.400
QFT Q-950 = 1.450
QFT Q-1050 = 1.590
it can be a challenge to get a large bore, downleg carb to leave hard with a 3.75 stroke motor in a heavy car.
also, sometimes the shift recovery isnt that great either.....although they often make good power on the dyno.
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859324
11/22/10 10:13 PM
11/22/10 10:13 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
are you runnin the carb in the pic.it looks like an HP holley not a holley with a removed air horn
if so i can send this one for you to test i just need it back by yhe columbus classic
WAXER
Re: CARB CHANGE EXPECTATIONS??!!! [Re: QWK_ENUF] #859325
11/22/10 10:30 PM
11/22/10 10:30 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thank You Tommy! The carb in the pic is a 950HP that is being loaned to me! The motor seems to like it! After reading Dwayne's advice,looks like I won't be going with the 1050 main body after all! I DO trust Dwayne! Maybe go with a 850 or 950 main body. The modified 850 that I was referring to is a loaner from P-Body! Works well! Just looking for a couple more mph! BTW..PRETTY CARB! What exactly is it??? Thanks Dwayne..Tommy!
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859326
11/22/10 10:37 PM
11/22/10 10:37 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
holler if you want to try it
WAXER
Re: CARB CHANGE EXPECTATIONS??!!! [Re: QWK_ENUF] #859327
11/22/10 10:51 PM
11/22/10 10:51 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
I'm hollering! Tommy,is it a 850,or 950???
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859328
11/22/10 11:06 PM
11/22/10 11:06 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Found this as i was "researching" the topic,,,,didnt realize it...
Quote from the Carb Shop.........
After all, 950 is more than 850 right? Wrong! In this case, Holley decided to rate their new line of "HP" carbs like their competition does, with inflated CFM figures. They had to. Otherwise no one would buy them because they are more expensive. An HP 950 Holley is a 750 main body with an 850 base. That makes it an 800. You can do the math. The "950," in this case, refers to the CFM potential, not the size of the venturi and throttle blade diameter
Re: CARB CHANGE EXPECTATIONS??!!! [Re: 69CHARGERMD] #859329
11/23/10 12:49 AM
11/23/10 12:49 AM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
I bet it runs best with the 950hp
Heavy street car with big venturi carb will be soft on the launch. Total flow isn't everything
Ron
Re: CARB CHANGE EXPECTATIONS??!!! [Re: QWK_ENUF] #859330
11/23/10 01:02 AM
11/23/10 01:02 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
That looks like & i'm sure it is a "procomp" mainbody with M.Blocks & bowls.
I hope you tried this carb out, i was going to try one of there mainbodies untill i was told to run are far away as possible from a carb builder i know, he said they have the worst casting amaginable, crappy workmenship, he bought one just for s*its & giggles (ya never know right!). you can more or less build a complete carb for 225.00-250.00, whats wrong with this picture Most if not all procomp stuff is junk.
Re: CARB CHANGE EXPECTATIONS??!!! [Re: fast68plymouth] #859331
11/23/10 01:38 AM
11/23/10 01:38 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
QFT Q-750 = 1.375
QFT Q-850 = 1.400
QFT Q-950 = 1.450
QFT Q-1050 = 1.590
Yep, my Gold Claw is set up w/ the 1.425" venturi / 1.75" baseplate. It made 5-8 HP more on the dyno than my old Holley "950 HP" and was quicker & faster on the track by a comparable amount, too.
I also saw a .2 and 2 MPH improvement on the track switching from a "traditional" Holley 850 to my old Holley "950 HP" and heard from some other people who saw similar improvements w/ the same change. Even though there may not be an outright improvement in HP seen on a dyno, the improvement in shift recovery on the track makes up for it.
Re: CARB CHANGE EXPECTATIONS??!!! [Re: BradH] #859332
11/23/10 02:03 AM
11/23/10 02:03 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
So,Brad...you think the 950HP would be my best bet??? Seems like that's what Dwayne's alluding to! Thanks for your on this!
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859333
11/23/10 02:42 AM
11/23/10 02:42 AM
Renton Washington
Triple Threat Offline
Renton Washington
I think most people are hinting you aren't going to see many gains switching from an 850 to a 950. If you're gonna do the swap, go to a dominator.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859334
11/23/10 02:58 AM
11/23/10 02:58 AM
BradH Offline
BradH  Offline
No, I'm not recommending you get a Holley "950 HP". I was giving an example that agreed w/ Dwayne's comment that a smaller carb that has better shift recovery will work better on the track than a larger (less responsive) carb that may actually make more HP.
As per Dwayne's guidelines, if you're going to stay w/ a 4150-type carb (and IMO you don't need a Dominator), my suggestion is to BORROW one w/ a venturi in the 1.40-1.45" range and see how it runs at the track compared to what else you have to compare against. IIRC, somebody has already lent you a QuickFuel or Proform 950 (1.45" v, compared to a Holley "950 HP" w/ a 1.38" v) to test, so that's the way to go.
Page 2 of 4 1 2 3 4
