Re: CARB CHANGE EXPECTATIONS??!!!
[Re: Labratt]
#859319
11/22/10 06:46 PM
11/22/10 06:46 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
I want more air flow..without hurting streetability, If I can get a couple of mph,and still have low-speed throttle response...I'll be a happy camper!
Then get a TR & 2 carbs , i'm serious, if your looking for flow, i will say this, unless your carb is jacked up & has issues & not tuned right, your not going to see enough gain to justicy the exspence going with another single carb, your 850 flows alot, more then a 950, thats where some get confused, they look at the larger #, but its just a #, all a 950 is is a tricked out 750 with an 850 base, like mentioned earlier, it'll most likely give you better 60ft. times which will help ET, but if your wanting "flow" & MPH get a TR, i'm sure it'll 60ft. & ET better too. Then you'll be a VERY happy camper.
[Re: joedust451]
#859321
11/22/10 09:23 PM
11/22/10 09:23 PM
Posts: 12,814 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
Why not just get a used Dominator and try it? You KNOW that they flow their rating. It is a shame that the cfm ratings on so many carbs are fiction.
Get a 1/2" adapter and a used Dominator (or better yet, borrow one) and see how it likes it.
Master, again and still
[Re: joedust451]
#859322
11/22/10 09:30 PM
11/22/10 09:30 PM
Posts: 1,463 oklahoma
forphorty
oklahoma
Check out Dwayne Porters numbers http://www.moparts.org/Tech/Archive/bb/8.html
[Re: Labratt]
#859323
11/22/10 09:40 PM
11/22/10 09:40 PM
Posts: 14,539 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
on a stock stroke 440 based combo, especially in a heavy car, if i were to be inclined to use a downleg booster carb, i'd stick with something that had a 1.425-1.450 max venturi diameter.
going from memory here.... Mighty Demon 750 = 1.400 Mighty Demon 825 = 1.425 QFT Q-750 = 1.375 QFT Q-850 = 1.400 QFT Q-950 = 1.450 QFT Q-1050 = 1.590
it can be a challenge to get a large bore, downleg carb to leave hard with a 3.75 stroke motor in a heavy car. also, sometimes the shift recovery isnt that great either.....although they often make good power on the dyno.
[Re: Labratt]
#859324
11/22/10 10:13 PM
11/22/10 10:13 PM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
are you runnin the carb in the pic.it looks like an HP holley not a holley with a removed air horn
if so i can send this one for you to test i just need it back by yhe columbus classic
WAXER
[Re: Labratt]
#859326
11/22/10 10:37 PM
11/22/10 10:37 PM
QWK_ENUF
LOWELL IN
holler if you want to try it
WAXER
[Re: Labratt]
#859328
11/22/10 11:06 PM
11/22/10 11:06 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Found this as i was "researching" the topic,,,,didnt realize it... Quote from the Carb Shop......... Quote:
After all, 950 is more than 850 right? Wrong! In this case, Holley decided to rate their new line of "HP" carbs like their competition does, with inflated CFM figures. They had to. Otherwise no one would buy them because they are more expensive. An HP 950 Holley is a 750 main body with an 850 base. That makes it an 800. You can do the math. The "950," in this case, refers to the CFM potential, not the size of the venturi and throttle blade diameter
[Re: QWK_ENUF]
#859330
11/23/10 01:02 AM
11/23/10 01:02 AM
joedust451
super gas
super gas
Branson, Mo.
That looks like & i'm sure it is a "procomp" mainbody with M.Blocks & bowls.
I hope you tried this carb out, i was going to try one of there mainbodies untill i was told to run are far away as possible from a carb builder i know, he said they have the worst casting amaginable, crappy workmenship, he bought one just for s*its & giggles (ya never know right!). you can more or less build a complete carb for 225.00-250.00, whats wrong with this picture Most if not all procomp stuff is junk.
[Re: fast68plymouth]
#859331
11/23/10 01:38 AM
11/23/10 01:38 AM
BradH
Yep, my Gold Claw is set up w/ the 1.425" venturi / 1.75" baseplate. It made 5-8 HP more on the dyno than my old Holley "950 HP" and was quicker & faster on the track by a comparable amount, too.
I also saw a .2 and 2 MPH improvement on the track switching from a "traditional" Holley 850 to my old Holley "950 HP" and heard from some other people who saw similar improvements w/ the same change. Even though there may not be an outright improvement in HP seen on a dyno, the improvement in shift recovery on the track makes up for it.
