Reverse manual Valve body vs Forward Shifting VB?
#857951
11/19/10 04:35 PM
11/19/10 04:35 PM
Posts: 4,281 Danville, NH
Mopar_Mike
Danville, NH
Why is it that everyone who builds race ready transmissions will only do it with a reverse shift valve body. Personally I prefer a forward shifting manual valve body, seems more natural.. Whats the big difference?
RS23L7 4-Speed
Re: Reverse manual Valve body vs Forward Shifting VB?
[Re: moparniac]
#857953
11/19/10 04:43 PM
11/19/10 04:43 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
yep and as a safety aspect with a rev pattern you are shifting away from N instead of towards it.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: Mopar_Mike]
#857954
11/19/10 04:48 PM
11/19/10 04:48 PM
Posts: 5,080 organ
maximum entropy
organ
purely a matter of preference. if you like forward pattern, go for it! cope has some very nice valve bodies. i have one in my turd and i absolutely love it. mine is reverse, but he and several others have forward pattern.
[Re: Mopar_Mike]
#857956
11/19/10 05:33 PM
11/19/10 05:33 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
This makes me ask a question. What about the "clean neutral" valve bodies I have heard about? It is my understanding, that it is a reverse pattern with a second neutral at the end of the pattern. In other words, is it possible to go to neutral at the end of a run and coast down to a stop? I am thinking that is the intention and purpose behind this. Maybe I'm wrong, but haven't talked to anybody about them. Also, if that is correct, it kind of makes the reverse pattern the same as regular forward pattern as far as accidentally going to neutral on a high gear shift. Am I not seeing this right? Any explanations of the 'clean neutral' are welcome and appreciated. I would like to go to neutral after a pass, but with reverse pattern,,,,
If you like drag racing, support your local track.
[Re: CHAPPER]
#857957
11/19/10 07:06 PM
11/19/10 07:06 PM
Posts: 7,506 Az
Crizila
Az
I didn't want to chop up my council, plus I wanted to use my factory shifter, so I went with a forward shifting valve body. Actually, mine is a cheeta valve body with an automatic up shift feature ( like a regular valve body ), so when I do a burn out, I just leave it in drive and it automatically upshifts to third. I then just release the line lock and roll out of the water in 3rd.
Fastest 300
[Re: Mr.Yuck]
#857960
11/19/10 09:22 PM
11/19/10 09:22 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
We use the reverse manual in my sons Dart and my car. I myself like to pull the shifter towards me when racing. It seems more natural pulling the shifter then it does pushing it as what I would have to do with a forward valve body. Ron
[Re: 383man]
#857961
11/19/10 09:33 PM
11/19/10 09:33 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I have a RMVB in mine and w/ a pro ratchet shifter It's a natural for me.
We put one in the 72 and W/ the factory slap stick it was a mess. I put a TA Manual/automatic FVB in it and it works great with the slap stick.
It's all just a mater of what works for what you want to do.
[Re: CHAPPER]
#857964
11/20/10 09:21 AM
11/20/10 09:21 AM
CHAPPER
Belpre,Ohio
Anybody have any info on this set-up?
[Re: CHAPPER]
#857965
11/20/10 09:53 AM
11/20/10 09:53 AM
kielbasa
i REALLY wanted to keep my slapstick, but trans builder talked me out of fmvb (since i'll have considerably more horsepower than stock) because he told me rmvb allows higher line pressure (or something to that effect) than fmvb......i will install the Duncan shift-r-gate, so at least i can still keep my slapstick though, haven't tried it out yet though.
[Re: kielbasa]
#857966
11/20/10 10:42 AM
11/20/10 10:42 AM
WILD BILL
BROOK PARK, OH
I bought the gate but couldn't really figure out how to install it with up cutting up and possibly ruining the slap stik shifter.
I have no idea why the shift pattern of any VB would affect the line pressure. What I do know is we took out a TA RMVB and installed the Manual/Atuomatic VB and the shifts were just as solid with either.
[Re: CHAPPER]
#857967
11/20/10 11:54 AM
11/20/10 11:54 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
CHAPPER You are correct in your assumtion I spoke with John Cope (CRT) and this option is only available with a trans brake. There are 2 neutrals one is after 3rd gear and the other shares the same position as reverse. To use reverse the trans brake button has to be activated. Shift pattern; P, R&N, 1st, 2nd, 3rd, N RMVB pattern; P, R, N, 1st, 2nd, 3rd
I like to go in neutral after the run also. At the moment my Quarter Stick is modified in the gate to slap it from 3rd to neutral after the run
Also talked with him about using a Forward VB and was recommended not to use with my HP & TQ level Really don't want to spend $800.00 for a Trans Brake VB that I'll never use being a Foot Brake racer.
Hope this clarifies things
[Re: roadhazard]
#857968
11/20/10 12:18 PM
11/20/10 12:18 PM
CHAPPER
Belpre,Ohio
Greg,,,,empty your PM box I just pecked out a message for about 20 minutes ,,,AND,,, unable to deliver
[Re: kielbasa]
#857970
11/20/10 03:58 PM
11/20/10 03:58 PM
BradH
i REALLY wanted to keep my slapstick, but trans builder talked me out of fmvb (since i'll have considerably more horsepower than stock)...
How much HP will that be? Just curious since I use a Turbo Action FMVB w/ about 600 HP and have no problems running in the 10s.
