Re: WHAT'S WITH LED LIGHTS?
[Re: cudaboone]
#856635
11/18/10 11:58 AM
11/18/10 11:58 AM
Posts: 21,084 Niles , Ohio
therocks
Niles , Ohio
You do know most dome lights in the older Mopars are a weird design.They have 2 contacts.One ground and one hot.Had a Dodge that I went crazy with at the shop with light problems.The guy replaced the dome bulb with the wrong bulb.Rocky
Chrysler Firepower
[Re: Cudajon]
#856637
11/18/10 01:29 PM
11/18/10 01:29 PM
Posts: 606 Montana
Yancy Derringer
Montana
I'm sitting here looking at the wiring diagram for the 72 cuda and I can't see how that could possibly happen.
I agree,-------except---------he must have some sort of wiring harness problem, IE the two circuits are interconnected as in some bare wire short, etc, in the harness
I don't find these to be a "weird design" at all. They simply have the switch in the ground leg. Power comes from the fuse, to the lamp, down to the switch, and ground.
[Re: Yancy Derringer]
#856638
11/18/10 02:21 PM
11/18/10 02:21 PM
therocks
Niles , Ohio
Its a wierd design as most ground thru the socket itself.Like I said I had one in that the guy installed the wrong bulbs and had all kind of problems.Most just see 2 posts on the bulb bottom or dont look at it and install a single contact and thats where you have problems.Just like when they install something like an 1157 backwards and cant figure out why the elements dont work properly.Rocky
Chrysler Firepower
[Re: Cudajon]
#856642
11/18/10 07:23 PM
11/18/10 07:23 PM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
You can't run incandescent AND LEDs at the same time...DAMHIK...Even the flashers that state they can run LEDs and stock bulbs, won't light up. I installed LEDs on my tail lights..one side at a time. The drivers side would light up and the passenger side would be dark. You have to put an electronic flasher on the turn signal side as well as the 4-way flasher. One thing to note for those who are doing the upgrade, the turn signal flasher with the terminals that are |_ ...I had to reverse those two wires for it to work. It was a gremlin that I couldnt trace until I tried it by pure luck...and it was successful
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Pyper70]
#856643
11/18/10 11:11 PM
11/18/10 11:11 PM
Posts: 1,805 ky hills
thehemikid
ky hills
...I put a 68 B-cuda wiring harness down the passenger side of my 70 tube chassis Cuda. I ran 1157's up front & these HITECH Products super bright (132 per side)LED's in the rear with the stock relay for 3 yrs & no problems on the street. The 1157's have to be working though or the LED's want. ...I used a Quick-connect in the front light harness at the fire wall for Quick dog house removal. Sometimes that connection rattled a little loose to the point my front blinker circuit on the passenger side wouldn't blink, & so also with the LED of the rear. Wire tied/fixed. The relay didn't know the LED's were there. The HITECH's are BRIGHT!
[Re: Cudajon]
#856644
11/19/10 09:22 AM
11/19/10 09:22 AM
Posts: 236 Maryland
cudaboone
Maryland
That flasher sounds suspect. I got mine from Superbrightleds and the number on it is 10R 02 702, 12v 30W, Made in EU, Name on it is ELECTRONIC FLASHER, There is no pigtail or anything like that it is just a 2 prong flasher that replaces the flasher connected to the ash tray back. (You did plug the flasher in the right place didn't you?).
The napa flasher is listed as LED compatable and it was plugged in correct. Do the four ways also have a flasher.
[Re: cudaboone]
#856647
11/19/10 11:48 AM
11/19/10 11:48 AM
Posts: 1,436 Oklahoma City OK
Cudajon
Oklahoma City OK
First I went out to the Sylvania website and printed out the Lamp Replacement guide for my car. Lamp Replacement Guide Then I went to Superbrightleds (this is not an endorsement I'm sure other sites have what you need) and ordered the 1157 and 1156 and their funky resisters to put inline so my turn signals would work. When they came in I took one look and there was no way I wanted to put those resisters in my wiring harness so I called them and they sent me the flasher. That was all I needed to get it working. I then ordered the amber 1157's for the front turn signals. I really like those they are much brighter than the original lights. I have replaced every bulb in the car with led's were available and love them. The dome light is a 211-2. I replaced all the dash lights too. Then I went with a halogen headlight kit and replaced that too. The first one used 100w bulbs and it melted the wires to my dimmer switch so I fixed the wires and went to 65w, no proplem so far. Im going with relays and new lights this winter, just haven't decided yet what I want to use. There hope that helps. DONT wire in any resisters, they look real bad, get hot, and they're not necessary. Oh yeah I never did replace the emergency flasher, I dont think I've ever had it on.
[Re: Cudajon]
#856648
11/19/10 03:30 PM
11/19/10 03:30 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
It might depend on whether there are ANY incandescents left in the circuit. Certainly, non-flashing circuits, like dome, running lights, etc. won't matter. But flashing circuits might still be sensitive/inoperative, even with a electronic flasher. That was the case with my car; everything outside (except for headlights, of course) is LED. The turn signals wouldn't work properly, because the load is just too low. Had to put resistors on the front turn signals for it all to work properly. Fortunately, since the resistors are only on the front turn signal bulbs, they don't heat up that much, and the additional electrical load is ONLY when using the turn signals (or four-way flashers, if necessary), but not when driving with lights on or when applying brakes.
My side markers are also LED. If they were still the incandescent 194s, it would work properly without the resistor. But that is only because I have them wired to flash with turn signal.
If the OP replaces all the fore/aft bulbs with LEDs, leaves the side markers as incandescent 194s, and wires the front side markers to flash with the turn signals (which is easy to do), it will probably work without any resistors, as long as an electronic flasher is used.
BTW, making the side markers flash with the turn signals is easy to do. Simply rewire the ground of the side marker pigtail to the turn signal wire of the front turn signal pigtail. The rears can be done the same way, except the wire from the turn signal must be run from the front of the car (or the appropriate wire of the dash harness) to the side marker. Otherwise the rear side markers would be activated also by the brake light(s).
[Re: Cudajon]
#856650
11/20/10 12:35 PM
11/20/10 12:35 PM
Posts: 236 Maryland
cudaboone
Maryland
Do you have the flasher number you got from supergrightled? They list 8 different 2 prong flashers. Tried to call them this am, but not open on saturday. Not worried about the emergency flashers either. Don't even know if they work. Never used them.
[Re: cudaboone]
#856651
11/20/10 03:22 PM
11/20/10 03:22 PM
Cudajon
Oklahoma City OK
Thats all thats on the flasher and the invoice says LED bulb flasher - FL2 - RED $12.95.
