carb orientation #856138
11/17/10 05:27 PM
11/17/10 05:27 PM
MD-USA
Dodgeguy101 Offline OP
MD-USA
This might be a silly question but have to ask anyway. Why are the carbs turned sideways on a tunnel ram, and if that is better for whateever reason, why wouldn't you turn them sideways on a single 4 manifold for the same reason?
Re: carb orientation [Re: Dodgeguy101] #856139
11/17/10 05:30 PM
11/17/10 05:30 PM
Guitar Jones Offline
Only the double pumpers are turned sideways and it's so they will fit in the limited space.
Re: carb orientation [Re: Dodgeguy101] #856140
11/17/10 05:57 PM
11/17/10 05:57 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
This might be a silly question but have to ask anyway...
I thought all "orientation" questions were supposed to be "Don't ask, don't tell" these days.
Re: carb orientation [Re: BradH] #856141
11/17/10 06:22 PM
11/17/10 06:22 PM
fresno ca
mikeysmopars Offline
fresno ca
Founder and CEO of the Central Valley Mopar Drag Pack
Re: carb orientation [Re: BradH] #856142
11/17/10 06:45 PM
11/17/10 06:45 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
there's little or no effect from launching that changes the fuel level and prevents tossing fuel out of the vents
jet changes are as simple as pulling the exposed bowls off.
home of the
Sox and Martin Hemi Duster
