A body rear springs #854879
11/15/10 10:58 PM
11/15/10 10:58 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
...how much lower will the rear of an A body sit if the front spring perch is reversed?
..'70 Duster, stock MP replacement springs.
Re: A body rear springs [Re: can.al] #854880
11/16/10 12:17 AM
11/16/10 12:17 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
You can't reverse them, the bolt pattern isn't rectangular.
Re: A body rear springs [Re: can.al] #854881
11/16/10 12:27 AM
11/16/10 12:27 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I have seen some cars lowered this way, and the result is about 2 inches of drop. To do this, you would need to oval out the mounting holes, which is not recomended!!!
The better way is to redrill a hole higher in the spring hanger. Good luck.
