Re: Stock height for a 66 Barracuda front end
[Re: in2oldies]
#854119
11/15/10 05:40 PM
11/15/10 05:40 PM
RapidRobert
checked according to the procedure in the shop manual which is measuring the diff between the height of 1 "adjusting blade" on the LCA compared to the bottom of the lowest point (?) in the LBJ arm it's 2" + - 1/8". Myself I'd set it where it looks good to you (jounce each end b 4 each adjustment) then have it aligned
