Over spray on interior door panels. #853533
11/14/10 07:36 PM
11/14/10 07:36 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Any way without destroying the grain texture?Thaxx inadav.
Re: Over spray on interior door panels. [Re: racerx] #853534
11/14/10 08:39 PM
11/14/10 08:39 PM
Kirkland, Washington
Pacnorthcuda Offline
Try brake fluid, you may have to let it sit on the surface a bit.
I have also had luck with lacquer thinner but thats riskier--you DON'T want to let that stay on the surface longer than required.
Re: Over spray on interior door panels. [Re: Pacnorthcuda] #853535
11/15/10 05:20 PM
11/15/10 05:20 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thaxx
Re: Over spray on interior door panels. [Re: racerx] #853536
11/15/10 05:22 PM
11/15/10 05:22 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Depending on how well cured it is, kerosene might work, and GoJo hand cleaner might do the trick also.
As always, trust your instinct or test in an inconspicuous area first.
Re: Over spray on interior door panels. [Re: Fury Fan] #853537
11/15/10 05:29 PM
11/15/10 05:29 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I just spray a little brake clean on a rag and wipe.
Re: Over spray on interior door panels. [Re: stumpy] #853538
11/15/10 09:04 PM
11/15/10 09:04 PM
IN
ahy Offline
ahy  Offline
IN
If all else fails, its not that hard to re-dye the panels. I've had good results with the SEM products (cleaner, primer, paint). They're available in kit form from Eastwood or the components can usually be purchased locally.
Re: Over spray on interior door panels. [Re: racerx] #853539
11/16/10 09:48 PM
11/16/10 09:48 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
I'm stripping a dash that someone painted right now with a product I found at Lowe's. It's water based, biodegradable, and contains no nasty solvents. Working surprisingly well. Called: Motsenbocker's Lift Off 4 - Spray Paint/Graffiti Remover.
Been using it on the plastic bezels and dash pad. It's taking the paint off right down to the vacuum plating.
Re: Over spray on interior door panels. [Re: racerx] #853540
11/17/10 12:03 PM
11/17/10 12:03 PM
VA
DAMOPARS Offline
DAMOPARS  Offline
VA
Goof off
