Steering Column shoe pin #853195
11/14/10 12:51 AM
11/14/10 12:51 AM
JJ6PACK Offline OP
JJ6PACK  Offline OP
I recently removed my column from 69 roadrunner.I can't remove the shoe pin from the shaft to rebuild the coupler top.Whats the secret?
Re: Steering Column shoe pin [Re: JJ6PACK] #853196
11/14/10 01:36 PM
11/14/10 01:36 PM
right between milan dragway & ...
Flite_727 Offline
Flite_727  Offline
IIRC it's pressed in.
'06 Magnum R/T Daily driver, 5.7 N.A.- [email]12.63@109[/email]
Re: Steering Column shoe pin [Re: JJ6PACK] #853197
11/14/10 01:56 PM
11/14/10 01:56 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Bench vice, BFH and drift punch.
Re: Steering Column shoe pin [Re: JJ6PACK] #853198
11/14/10 02:24 PM
11/14/10 02:24 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
if you are talking about the fat pin that goes through the shaft to locate the two shoes, i just left mine in when i rebuilt my coupler. i replaced everything else but didn't see any wear or damage to that pin and i didn't have a press at the time and didn't want to mangle the shaft trying to get that pin out.
Re: Steering Column shoe pin [Re: dirtybee] #853199
11/14/10 04:53 PM
11/14/10 04:53 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
If the pin is not worn, leave it in. The new coupler seals will stretch over the pin. Don't try to stretch an NOS original style coupler seal over the pin, it will split the lip.
Top is an original seal, other two are replacements.
Re: Steering Column shoe pin [Re: JJ6PACK] #853200
11/15/10 07:52 PM
11/15/10 07:52 PM
JJ6PACK Offline OP
JJ6PACK  Offline OP
Thanks moparts. I left it in and didn't split the new rubber.
