Unknown Erson cams..... Please help #852793
11/13/10 08:05 PM
11/13/10 08:05 PM
Seattle Wa
PowerWagonDude Offline OP
Seattle Wa
Today I bought two new Erson cams and a set of sig erson lifter all for $40 on Craigslist. There were no cam cards or parts numbers. One cam has the distributor drive gear in front so I think it is bigblock. It is stamped on the front Erson RV-10-H B104S4, the other has distributor drive gear in back. It is stamped Erson HiFlow 1H B107S1. The lifters had a part number of 914651 wich I think should be E914651. I traced that number to the smallblock engine, However I would like to use the lifters for the bigblock cam. Can I do this? Any help in identifying these cams will help. I want to use these in my trucks so I dont want to install a racing cam. Thanks
Re: Unknown Erson cams..... Please help [Re: PowerWagonDude] #852794
11/13/10 09:23 PM
11/13/10 09:23 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Call Tom at Auto Marine Machine in Carson City, NV
775-841-3886. Tom was the main man at Erson Cams when Mr.Gasket Co was operating in Carson City. He's a great guy & should be able to help you.
Re: Unknown Erson cams..... Please help [Re: Triggerfish] #852795
11/14/10 03:18 AM
11/14/10 03:18 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
This is what I found in my old Erson Catalog for small block
E420421 part number HI Flow IH
intake/exhaust 290 advertise duration
228/228 @ .050 duration
.472 lift intake/exhaust
108 Lobe Center
Tony
70 AARCuda Vitamin C
Re: Unknown Erson cams..... Please help [Re: 70AARcuda] #852796
11/14/10 03:21 AM
11/14/10 03:21 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
big block lifters are listed as E914641
Tony
Re: Unknown Erson cams..... Please help [Re: 70AARcuda] #852797
11/14/10 03:24 AM
11/14/10 03:24 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
the RV10H is not listed under the big block section of the catalog...they do have it listed under the small block section..
I can email you this catalog since it is a PDF file.
Tony
Re: Unknown Erson cams..... Please help [Re: 70AARcuda] #852798
11/14/10 03:32 AM
11/14/10 03:32 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
How about looking that second cam up as a Hemi since Big Block & Hemi look very similar but the intake & exhaust lobe positions are out of order...
Re: Unknown Erson cams..... Please help [Re: 1_WILD_RT] #852799
11/14/10 02:45 PM
11/14/10 02:45 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
the catalog does not show any hydraulic cams for 426 hemis...
if anyone wants a copy of catalog..just PM me your email address...
Tony
Re: Unknown Erson cams..... Please help [Re: 70AARcuda] #852800
11/14/10 03:37 PM
11/14/10 03:37 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Big block and small block have the same lifter diameter, so it should be no problem using them on either cam .
Re: Unknown Erson cams..... Please help [Re: PowerWagonDude] #852801
11/14/10 07:21 PM
11/14/10 07:21 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Erson did offer hydraulic Hemi cams though. I had two Hemi's with Super Hiflow II's in them and they worked just great in a stock 426 hemi (like high 11's with headers but otherwise stock).
Sheldon
Re: Unknown Erson cams..... Please help [Re: 70AARcuda] #852802
11/14/10 11:07 PM
11/14/10 11:07 PM
CentralVA.
BBCoronet Offline
BBCoronet  Offline
CentralVA.
I dont see my cam in the catalog either......The cam I have was bought in the mid/late 70s so maybe it was replaced with another part # ??? Anyone have any ideas??
