Aspen Wagon #852706
11/13/10 08:19 PM
11/13/10 08:19 PM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
Have an opportunity to pick up an Aspen wagon for free. It's a 318 auto car. I haven't taken a good look under it yet. Can anyone tell me what this thing weighs as opposed to an A-body? Also, would this have come with an 8 1/4 rear in it? I have a slightly warmed over 360 I'd like to put in it. Basically stock with a cam change. specs on cam at .050 are .221 intake .224 exhaust .445 lift intake and .465 exhaust. Factory spreadbore intake and headers. I am assuming it has a 904. How long with it hold up to a 360 before I have to tweak it? Thanks.
Re: Aspen Wagon [Re: elmor] #852707
11/13/10 10:14 PM
11/13/10 10:14 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
http://www.allpar.com/model/aspen-volare-specs.html
the wagon is the same as a 4 door sedan, really, with a back cargo area, in place of the trunk. it will "hotrod" as easily as a 2 door, or 4 door sedan. scroll down on the page i linked to, for weights for each model.
Re: Aspen Wagon [Re: elmor] #852708
11/13/10 11:02 PM
11/13/10 11:02 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Properly built with stock parts the 904 will go forever with your combo. A 727 fits with no problem. A 66-70 b-body 8 3/4 will bolt in if you use the lower shock plates as well. They are heavier than a A-body.
Doug
Re: Aspen Wagon [Re: dvw] #852709
11/13/10 11:50 PM
11/13/10 11:50 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The 8.25 axle was available in the F body cars, but from my wrecking yard scrounging, the ratio was about 65% were 7.25 axle equipped.
Re: Aspen Wagon [Re: Golden-Arm] #852710
11/14/10 07:09 AM
11/14/10 07:09 AM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
Thanks for the link. From what I read there the rear should be an 8 1/4. It said that the wagons and V-8 cars, along with heavy duty applications had the 8 1/4. This is a V-8 wagon, so it's a pretty reasonable assumption. What kind of after market gears and sure-grip units are available?
Re: Aspen Wagon [Re: elmor] #852711
11/14/10 12:56 PM
11/14/10 12:56 PM
Everywhere
moparboy76 Offline
moparboy76  Offline
Everywhere
Ive had a 904 running behind my 360 for several years it got hot rodded everytime it got drove the trans never gave me a problem until i let it set without fluid in a shop on the floor now shes a boat anchor. 904's are pretty darn tough.
Re: Aspen Wagon [Re: moparboy76] #852712
11/14/10 08:08 PM
11/14/10 08:08 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
IIRC, all V-8 F-body wagons got the 8-1/4" rearend....maybe even all wagons, period.
Wagons are always heavy with the extra glass and body surface, so add 300-400 pounds over an A-body.
Re: Aspen Wagon [Re: In_The_Pink] #852713
11/14/10 08:40 PM
11/14/10 08:40 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
All F and M body wagons came with 8-1/4...
Ratios were either 2.4,2.9 or 3.2 in wagons.
1980 Volare Super Six with 8-1/4 rear..nevermind the weird trailer hitch attached to the rear axle.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
