Re: W-5 roll call ......! [Re: 72demon416] #852336
11/16/10 11:13 PM
11/16/10 11:13 PM
CA.
RAY1969CARS Offline OP
CA.
what cam should i run ?????? roller cam or flat ?? what lift ??? what compression ? whats the highest rpm with what im running ??
Re: W-5 roll call ......! [Re: RAY1969CARS] #852337
11/16/10 11:25 PM
11/16/10 11:25 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
I have a set. The combo they sit on is a wooden shelf. Haven't gotten around using them yet.
-Kenny
Re: W-5 roll call ......! [Re: StrokerAspen] #852338
11/16/10 11:38 PM
11/16/10 11:38 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Been looking for a set so I can join your club!
I had a few sets of the early W2's (back in like 78-or 9)...and I WISHED they were aluminum...does that get me honorary mention?
WIZE
In Car:
Re: W-5 roll call ......! [Re: RAY1969CARS] #852339
11/17/10 01:14 AM
11/17/10 01:14 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
What are your intentions with this thing- street/strip or drag only? pump gas or race gas?
Either way I wouldn't be using that cast crank - how many times do you want to build it?
The large plenum M1 is not the hot ticket for 360 cubes and as mentioned a 950 would be a better choice.
If your wanting max power there can only be 1 choice- solid roller- how high do you want to spin it?
Re: W-5 roll call ......! [Re: 72demon416] #852340
11/17/10 02:21 AM
11/17/10 02:21 AM
CA.
CA.
i would like to spin it to at least 7300 im thinking of a scat crank ? so u think the profrom 750 is too small??? plus i would like to get the most compression i can get out of the flat tops. it would be mostly used on the strip but car shows here and there ps race gas
Re: W-5 roll call ......! [Re: RAY1969CARS] #852341
11/17/10 03:43 PM
11/17/10 03:43 PM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
Yes I think the 750 is too small...it will work but you'll be shorting yourself on power. Look at the post of my buildup- Ryan dyno'd mine with a 950 and 2 1050's and found 20 hp difference. Now I am temporarily running my old 825 Demon and it runs GREAT but is it down on power compared to what it should be? OH YEA!
Call the pro's on this board when your ready for a cam- you could get 50 different answers here and they all might be fine but you've got to pick somebody for that 1.
Re: W-5 roll call ......! [Re: 72demon416] #852342
11/17/10 09:50 PM
11/17/10 09:50 PM
aZLiViN
J_BODY Online rolleyes
J_BODY  Online Rolleyes
aZLiViN
Even our somewhat mild iron MP headed 360 liked the 960 BG carb we threw on it. That combo set a best of 10.91/92's. One thing I'm not overly comfortable with (on the W5) is the stock block we had access to. We just plain ran out of funds for a race block so did the best with what we had. Our 340 block is filled and does have aftermarket steel caps (two bolt). We're hoping it lasts. we also left some hp on the table in the cam dept as we didn't want a high maint valve spring eater.
Re: W-5 roll call ......! [Re: J_BODY] #852343
11/18/10 01:23 AM
11/18/10 01:23 AM
CA.
CA.
i wish i had more cash !! lololol you guys wouldnt beleave what i payed for all that stuff i found good deals on ebay and at the spring fling !!!i got all my w5 stuff complete 4 less then 2000 all band new ! ? heads rocker /shafts hold down intake value covers where 120 headers 275.00 oil pan was 200 i will goo with a scat crank but cant buy a race block! how far can i spin that scat crank in a stock block ??? plus i guess i need a 950 carb now !!! wow ! but all in all its not a bad build !
Re: W-5 roll call ......! [Re: RAY1969CARS] #852344
11/18/10 11:18 AM
11/18/10 11:18 AM
aZLiViN
aZLiViN
Yeah just getting a set of heads for free can be a death sentence for your bank account. By the time you port them, and build the rest of the package around them so you can take advantage of how they work, it can get a little expensive. If I remember correctly we have about 9k into our build....and that started with a set of $800 used heads that were on an ARCA car out of michigan. Not a huge amount in this arena, but pretty good for our standards.
Re: W-5 roll call ......! [Re: J_BODY] #852345
11/18/10 06:07 PM
11/18/10 06:07 PM
CA.
CA.
ya funny ! i was just going to buy some eddy heads a cam and be done with it !!!!!!!!!1lololol then i saw the w5s lolol i wouldve been done buy now! lolol
Re: W-5 roll call ......! [Re: Guitar Jones] #852346
11/18/10 06:39 PM
11/18/10 06:39 PM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
W5s here, .020 over MP short block, soon to be replaced with a 408 and a .700 net lift roller with 2.08 valves.
you need to put some air in those slicks!!!!!!
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: W-5 roll call ......! [Re: StripeHOG] #852347
11/25/10 10:06 AM
11/25/10 10:06 AM
Louisville, MS
Dustedu Offline
Dustedu  Offline
Louisville, MS
DI'm still running my 396 W-5 engine, after eight years she still runs 9.80's @ 138 went 5.70's last weekend on 150 shot and 275's
Re: W-5 roll call ......! [Re: Dustedu] #852348
11/25/10 12:04 PM
11/25/10 12:04 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I will have a pair for sale soon along with an intake, they are the " good" ones with the blue plug. They have never been used and come with valves.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: W-5 roll call ......! [Re: 11secdart] #852349
11/26/10 12:22 PM
11/26/10 12:22 PM
western PA
stevet340 Offline
stevet340  Offline
western PA
I have a set off my car I'd like to sell. Complete with valves, springs, sheetmetal tunnel ram, smith brothers pushrods, Harland Sharp 1.6 rockers. Only 40 passes on everything since new! I split the stock block in half and went to a race block and W9s. Car went 9.50s @ 2900lbs N/A 360 cubic inches. PM me if you are interested.
Re: W-5 roll call ......! [Re: StripeHOG] #852350
11/26/10 09:13 PM
11/26/10 09:13 PM
Guitar Jones Offline
Ha ha, they work though. That car hooks when nothing else does.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: W-5 roll call ......! [Re: Guitar Jones] #852351
12/12/10 05:01 PM
12/12/10 05:01 PM
CA.
CA.
question ! i live in cal. who ported your heads ?????? in wanted to send them to shady dell's but is there some one closer ?? who did your ???
Re: W-5 roll call ......! [Re: RAY1969CARS] #852352
12/12/10 07:04 PM
12/12/10 07:04 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Of all those who posted combo's on this post, I did the heads for:
W5Duster364
W5Dart378
barryc
340RICK
greendart408
JBODY
DavidDean
72Demon416
Brian @ IMM (Ou812) could do good job for you in CA so you don't have to ship them cross Country. He is only one on west coast I'd recommend.
Re: W-5 roll call ......! [Re: RyanJ] #852353
12/12/10 11:19 PM
12/12/10 11:19 PM
aZLiViN
aZLiViN
...our 5's went from Michigan to Arizona, to PA, to South Dakota, to PA, and back to SoDak. Should have got frequent flyer miles for them. Thanks again for a great set of heads Ryan. My dad is having a ball with that engine!
