Re: W-5 roll call ......!
[Re: 72demon416]
#852336
11/16/10 11:13 PM
11/16/10 11:13 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
what cam should i run ?????? roller cam or flat ?? what lift ??? what compression ? whats the highest rpm with what im running ??
[Re: StrokerAspen]
#852338
11/16/10 11:38 PM
11/16/10 11:38 PM
Posts: 9,874 Weddington, N.C.
Streetwize
Weddington, N.C.
Been looking for a set so I can join your club! I had a few sets of the early W2's (back in like 78-or 9)...and I WISHED they were aluminum...does that get me honorary mention?
[Re: RAY1969CARS]
#852339
11/17/10 01:14 AM
11/17/10 01:14 AM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
What are your intentions with this thing- street/strip or drag only? pump gas or race gas? Either way I wouldn't be using that cast crank - how many times do you want to build it? The large plenum M1 is not the hot ticket for 360 cubes and as mentioned a 950 would be a better choice. If your wanting max power there can only be 1 choice- solid roller- how high do you want to spin it?
[Re: 72demon416]
#852340
11/17/10 02:21 AM
11/17/10 02:21 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
i would like to spin it to at least 7300 im thinking of a scat crank ? so u think the profrom 750 is too small??? plus i would like to get the most compression i can get out of the flat tops. it would be mostly used on the strip but car shows here and there ps race gas
[Re: Dustedu]
#852348
11/25/10 12:04 PM
11/25/10 12:04 PM
Posts: 4,976 new jersey usa
11secdart
new jersey usa
I will have a pair for sale soon along with an intake, they are the " good" ones with the blue plug. They have never been used and come with valves.
[Re: StripeHOG]
#852350
11/26/10 09:13 PM
11/26/10 09:13 PM
Guitar Jones
W5s here, .020 over MP short block, soon to be replaced with a 408 and a .700 net lift roller with 2.08 valves.
you need to put some air in those slicks!!!!!!
Ha ha, they work though. That car hooks when nothing else does.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: RAY1969CARS]
#852352
12/12/10 07:04 PM
12/12/10 07:04 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
question ! i live in cal. who ported your heads ?????? in wanted to send them to shady dell's but is there some one closer ?? who did your ???
Of all those who posted combo's on this post, I did the heads for:
W5Duster364 W5Dart378 barryc 340RICK greendart408 JBODY DavidDean 72Demon416
Brian @ IMM (Ou812) could do good job for you in CA so you don't have to ship them cross Country. He is only one on west coast I'd recommend.
