W-5 roll call ......!
#852316
11/13/10 12:51 AM
11/13/10 12:51 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
pics and set up your running ? mopar are no car! p.s. 1/4 and 1/8 mile times
Re: W-5 roll call ......!
[Re: W5Duster436]
#852318
11/13/10 02:02 AM
11/13/10 02:02 AM
Posts: 489 mid Ga.
W5Dart378
mid Ga.
My 422 W5 combo went a best of 6.15 on alcohol at around 3200 before I started spaying it. Then started finding the week link regularly. Went 5.66 with 250 shot.
69 340 swinger streetcar 8.13 1/8th w/1.90 60ft w/ 3.55s
69 422W9 Dart stock suspension,5.27 on 275/60s,single bar plate
[Re: RAY1969CARS]
#852319
11/13/10 10:00 AM
11/13/10 10:00 AM
Posts: 53 New Jersey
barryc
New Jersey
1972 challenger 9.08 @ 146 at atco. Engine built by G&S Performance. Heads ported by Ryan J.
[Re: W5Dart378]
#852320
11/13/10 10:04 AM
11/13/10 10:04 AM
barryc
New Jersey
engine pic
[Re: barryc]
#852325
11/14/10 03:59 PM
11/14/10 03:59 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
im putting togather a w5 360 please feel in the blanks for max horse power ? i want to stay around 630 lift with a roller stock stoke 360 cast stock block 750 profrom m1 large runner w5 heads cc ported with 202 or 205 and 160 pistons srp flat tops scat rods hooker 1 7/8 adj please feel in the blank and what could do and whats wrong car 69 dart 29/11 slick 456 spool ladder bar or cal-trac ???? 727 with 4500 please help me make a cool car mopar or no car
[Re: RAY1969CARS]
#852328
11/14/10 07:23 PM
11/14/10 07:23 PM
Posts: 1,073 oregon
greendart408
oregon
My combo.. no pics on my phone though. 3100lb 11.5 tire, 69 dart. ladder bar, 727 trans 408cu.R block, W5s injected on alky roller cam... So far 6.13@113.05 1/8th 9.63@139.57. If I can ever get it to 60 decent it will run consistent 50s easy enough. Only has went 1.36 and usually 1.37. 60ft. Just spins horribly at the hit. And if it does hook initially it will unload when the tires touch back down. This is also with no hood as the injectors are to close to the bottom of the hemi scoop.
[Re: Brian Hafliger]
#852330
11/14/10 09:35 PM
11/14/10 09:35 PM
Posts: 3,998 GO BUCKS !!!!!!!
340RICK
GO BUCKS !!!!!!!
Yes a 950 or 1000 4150 carb would be good. Your short block is OK at best a stock block and stock 360 cast crank. You can make 600 HP with W5's and a INDY intake easy. That is not good for a stock block and cast crank. I would keep your RPM's 6500 or less
[Re: DavidDean]
#852333
11/15/10 09:55 AM
11/15/10 09:55 AM
Guitar Jones
W5s here, .020 over MP short block, soon to be replaced with a 408 and a .700 net lift roller with 2.08 valves.
[Re: RAY1969CARS]
#852335
11/16/10 10:29 PM
11/16/10 10:29 PM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
Shady Dell built pump gas 439", small chamber ported w5's, 10.7-1, bullet solid roller 272/276 @ .725, R3 siamese, Howards ultimate rods, K1 crank, Diamond pistons, TTI's, M1 intake (temporary) with Indy intake, and 1050 Dominator to go on. Will likely see a vacuum pump in spring. 660 HP at the moment- only to go higher... No times yet- should be a mid-low 10 sec car with traction. All I know is with E70-14's on it's a handful, still lays rubber @ 80+ mph thru 3'rd gear and sounds sweet @ 7500. GOOD STUFF!
