1956 Dodge truck project
#850271
11/09/10 10:17 PM
11/09/10 10:17 PM
Posts: 76 Port St Lucie, Florida
towguy76
just bought a 56 Dodge truck that has been sitting for a few years. some one had previously customized the truck and added a 440 engine, tilt steering column, pedal assembly with master cylinder, 8 3/4 rear end and guage cluster out of i believe a 69-70 Imperial. I have yet to run the numbers on the motor, but the friend i bought it from (not the person who did all the work) said he ran the numbers a few years ago and remebers it being a steel crank motor. It also has the 3 speed pushbutton trans in it. i have had several late 60s and early 70s Mopars but this is my first 50s vehicle. it will be a learning experience. [image] [/image]
Rick
Re: 1956 Dodge truck project
[Re: Randy..]
#850274
11/10/10 02:10 AM
11/10/10 02:10 AM
Got any more pics of that mustang in the back ground
[Re: towguy76]
#850281
11/11/10 07:18 PM
11/11/10 07:18 PM
towguy76
Can anyone tell me what this speedometer came out of? Can't place it for the life of me. Not sure if it is even a Mopar part. I know it isn't original to this truck. Thinking maybe late 60s Lincoln? [image] [/image]
Rick
[Re: towguy76]
#850282
11/11/10 10:47 PM
11/11/10 10:47 PM
I would bet a case of beer that the wood face plate was home made.
[Re: ]
#850284
11/15/10 10:08 AM
11/15/10 10:08 AM
towguy76
Oh i am sure of that. there is a matching wood panel on the passenger side of the dash. Was curious about the speedo gauge that is behind the wooden bezel though.
Rick
[Re: joedust451]
#850287
12/13/10 03:09 AM
12/13/10 03:09 AM
towguy76
Alright, finally got the truck to work. The 440 looks to be a 68 10:1 motor. I am starting to think the engine, p. steering box, tilt/ telescoping column, pedal assembly, brake master and 8 3/4 rear (with huge drum brakes and factory pinion snubber) came out of possibly a 68 Imperial. The trans is a big block push button 3 speed auto trans. I am not sure what year it is. They only made the push button 3 speed trans from 56 to 63 but unsure when they first had the big block bolt pattern.
Rick
[Re: towguy76]
#850288
12/25/10 12:19 PM
12/25/10 12:19 PM
towguy76
Brought the truck to work finally. Got the engine to spin over eventually. Haven't fired it up yet though. Don't know if i like the butterfly hood yet. It's cool, but it makes it a pain to work on the engine. Also it has no way of locking the hood to prevent theft of parts.
Rick
[Re: towguy76]
#850289
12/27/10 01:20 PM
12/27/10 01:20 PM
Posts: 4,046 Minnesota
72blubird
Minnesota
Curious what kind of exhaust manifulds or headers it has...a pic would be fantastic. I have a 56 with 400/727/8 3/4 in it
What was I thinking....
