1956 Dodge truck project #850271
11/09/10 10:17 PM
11/09/10 10:17 PM
Port St Lucie, Florida
towguy76 Offline OP
towguy76  Offline OP
just bought a 56 Dodge truck that has been sitting for a few years. some one had previously customized the truck and added a 440 engine, tilt steering column, pedal assembly with master cylinder, 8 3/4 rear end and guage cluster out of i believe a 69-70 Imperial. I have yet to run the numbers on the motor, but the friend i bought it from (not the person who did all the work) said he ran the numbers a few years ago and remebers it being a steel crank motor. It also has the 3 speed pushbutton trans in it. i have had several late 60s and early 70s Mopars but this is my first 50s vehicle. it will be a learning experience. [image][/image]
Rick
Re: 1956 Dodge truck project [Re: towguy76] #850272
11/09/10 10:23 PM
11/09/10 10:23 PM
towguy76 Offline OP
towguy76  Offline OP
Rick
Re: 1956 Dodge truck project [Re: towguy76] #850273
11/09/10 10:58 PM
11/09/10 10:58 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
get rid of all them custom touches, put on some factory steels drive the crap out of it.
Re: 1956 Dodge truck project [Re: Randy..] #850274
11/10/10 02:10 AM
11/10/10 02:10 AM
Got any more pics of that mustang in the back ground
Re: 1956 Dodge truck project [Re: ] #850275
11/10/10 11:16 AM
11/10/10 11:16 AM
towguy76 Offline OP
towguy76  Offline OP
No i don't. One of the guys i work with bought it. It belonged to the same guy i bought the truck from. Supposed to be a 71 Mach 1, has a fiberglass hood, bumper, hood and such. I believe it has a 351 Cleveland in it.
Rick
Re: 1956 Dodge truck project [Re: Randy..] #850276
11/10/10 11:21 AM
11/10/10 11:21 AM
towguy76 Offline OP
towguy76  Offline OP
I plan on removing the bumpers, console, changing the interior, flat blacking it out. And installing a set of Mopar cop car wheels.
Rick
Re: 1956 Dodge truck project [Re: towguy76] #850277
11/10/10 11:39 AM
11/10/10 11:39 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
I like the paint patina just the way it is.
Re: 1956 Dodge truck project [Re: towguy76] #850278
11/10/10 11:15 PM
11/10/10 11:15 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I thought big rear windows were'nt available until 57? I could be wrong.
Neat truck, with that 440 make sure you're on a wide, empty road before opening it up.
Sheldon
Re: 1956 Dodge truck project [Re: Dave Watt] #850279
11/11/10 07:10 PM
11/11/10 07:10 PM
towguy76 Offline OP
towguy76  Offline OP
Problem is, i can't stand the color.
Rick
Re: 1956 Dodge truck project [Re: RUNCHARGER] #850280
11/11/10 07:12 PM
11/11/10 07:12 PM
towguy76 Offline OP
towguy76  Offline OP
Sheldon
55 1/2 was the first year for the wraparound windsheild. 56 was the first year for the large rear glass. 57 they changed the front sheetmetal and got rid of the butterfly hood.
Rick
Re: 1956 Dodge truck project [Re: towguy76] #850281
11/11/10 07:18 PM
11/11/10 07:18 PM
towguy76 Offline OP
towguy76  Offline OP
Can anyone tell me what this speedometer came out of? Can't place it for the life of me. Not sure if it is even a Mopar part. I know it isn't original to this truck. Thinking maybe late 60s Lincoln?
[image][/image]
Rick
Re: 1956 Dodge truck project [Re: towguy76] #850282
11/11/10 10:47 PM
11/11/10 10:47 PM
I would bet a case of beer that the wood face plate was home made.
Re: 1956 Dodge truck project [Re: towguy76] #850283
11/12/10 12:04 AM
11/12/10 12:04 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
That's a neat ol truck you found! I had a 56 with a 440/727 in it back in the early 80's. Mine had the big back window also. Sheldon is right about a straight,empty road! If it has the stock steering box in it.....it ain't any bigger than your fist and requires considerable effort to keep up with the steering. Good luck.
Re: 1956 Dodge truck project [Re: ] #850284
11/15/10 10:08 AM
11/15/10 10:08 AM
towguy76 Offline OP
towguy76  Offline OP
Oh i am sure of that. there is a matching wood panel on the passenger side of the dash. Was curious about the speedo gauge that is behind the wooden bezel though.
Rick
Re: 1956 Dodge truck project [Re: JDMopar] #850285
11/15/10 10:14 AM
11/15/10 10:14 AM
towguy76 Offline OP
towguy76  Offline OP
You pair that with the tiny chain steering wheel that is currently on it and with was probably a bear to drive.
Rick
Re: 1956 Dodge truck project [Re: towguy76] #850286
11/16/10 03:28 AM
11/16/10 03:28 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Ahhh "Essa" wheres the fuzzy dize & the twize-pipes- Hee-Hee.
Its a cool truck, scrap the goofy steering wheel, dress it in black.
Those peddles look offly familiar , New yorker or Newport i'd say.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: 1956 Dodge truck project [Re: joedust451] #850287
12/13/10 03:09 AM
12/13/10 03:09 AM
towguy76 Offline OP
towguy76  Offline OP
Alright, finally got the truck to work. The 440 looks to be a 68 10:1 motor. I am starting to think the engine, p. steering box, tilt/ telescoping column, pedal assembly, brake master and 8 3/4 rear (with huge drum brakes and factory pinion snubber) came out of possibly a 68 Imperial. The trans is a big block push button 3 speed auto trans. I am not sure what year it is. They only made the push button 3 speed trans from 56 to 63 but unsure when they first had the big block bolt pattern.
Rick
Re: 1956 Dodge truck project [Re: towguy76] #850288
12/25/10 12:19 PM
12/25/10 12:19 PM
towguy76 Offline OP
towguy76  Offline OP
Brought the truck to work finally. Got the engine to spin over eventually. Haven't fired it up yet though. Don't know if i like the butterfly hood yet. It's cool, but it makes it a pain to work on the engine. Also it has no way of locking the hood to prevent theft of parts.
Rick
Re: 1956 Dodge truck project [Re: towguy76] #850289
12/27/10 01:20 PM
12/27/10 01:20 PM
Minnesota
72blubird Offline
72blubird  Offline
Minnesota
Curious what kind of exhaust manifulds or headers it has...a pic would be fantastic. I have a 56 with 400/727/8 3/4 in it
What was I thinking....
Re: 1956 Dodge truck project [Re: 72blubird] #850290
12/27/10 09:11 PM
12/27/10 09:11 PM
JDMopar Offline
JDMopar  Offline
The 56 that I had, with a 440/727 in it had HP manifolds if I remember correct. Too much motor....not enough steering box!
