Deep staging ? #848667
11/08/10 10:06 AM
11/08/10 10:06 AM
South Jersey, NJ
DragDart360 Offline OP
South Jersey, NJ
How much difference in RT will you get by deep staging.
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: Deep staging ? [Re: DragDart360] #848668
11/08/10 10:46 AM
11/08/10 10:46 AM
Out West
408strokerdart Offline
Out West
about .10 slower et.
Re: Deep staging ? [Re: DragDart360] #848669
11/08/10 10:49 AM
11/08/10 10:49 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Many cars I've raced would not cut a quick enough reaction time. Over the years I've learned to "bump" them in. Seldom have I had a car that needed to go all the way deep(top bulb out).
I've found one bump is usually worth about .030 in R/T. For instance at the Norwalk Chrysler Classic I made 4 passes shallow staged. All between .060-.068 R/T. Not good enough to go very far in eliminations. Bumping in the next 9 out of 10 passes were .004-.030. As you can see it is not as accurate as your bump in distance will very. It also will slow your E.T. by a similar amount. Still it works better than being slow. It just takes practice. There is aprox 4 bumps to turn the top bulb off in my case.
Doug
Re: Deep staging ? [Re: dvw] #848670
11/08/10 10:55 AM
11/08/10 10:55 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
from the newbie guy here who's only raced once or twice... can you stage so deep the top bulb goes out, and still be legal? I thought you had to have both lights on to be properly/legally staged?
i understand the difference between deep and shallow, and how it affects RT vs ET, just wondered about the bulbs!
**Photobucket sucks**
Re: Deep staging ? [Re: 70Cuda383] #848671
11/08/10 11:27 AM
11/08/10 11:27 AM
South Jersey, NJ
South Jersey, NJ
Thanks for the replys Yes it's legal at most tracks to deep stage (check your tracks rules)
Most tracks near me no longer allow DEEP to be on the cars window but it's legal to deep stage (top bulb out)
Re: Deep staging ? [Re: DragDart360] #848672
11/08/10 02:34 PM
11/08/10 02:34 PM
WI
mopar873 Offline
mopar873  Offline
WI
FWIW my 60 ft time changes from 1.41 to 1.50 when deep staging, and I lose just over a tenth in ET.
Re: Deep staging ? [Re: mopar873] #848673
11/08/10 02:38 PM
11/08/10 02:38 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I just saw a pinks all out where they D.Q'd a driver for deep staging. They said he left early cause the top bulb went out.
67' charger 499 RB 10.57 at 127
Re: Deep staging ? [Re: DragDart360] #848674
11/08/10 03:28 PM
11/08/10 03:28 PM
Brea, Ca
Dart Racer Offline
Dart Racer  Offline
Brea, Ca
I just started deep staging this weekend and during the past two seasons on a .4 pro tree, my RT averaged .108 with a best of .089 and a worst of 1.39
This weekend I averaged .021 with a best of .007 and the worst was .039
60's went from 1.45's to 1.58's. Since I run an index class the end et was still a 10.60, but if et matters you would lose a time roughly equal to the loss in 60'
Footbrake
3360 lbs
Auto
Re: Deep staging ? [Re: dragram440] #848675
11/08/10 06:19 PM
11/08/10 06:19 PM
Hartford,MI
goody340g Offline
goody340g  Offline
Hartford,MI
don't get me wrong i watch it but, you can't go by that its not even real racing. they make stuff up as they go.
Re: Deep staging ? [Re: 70Cuda383] #848676
11/08/10 09:46 PM
11/08/10 09:46 PM
Toronto Ontario
Butt Ugly Offline
Butt Ugly  Offline
Toronto Ontario
Learned the hard way about deep staging at the track, top light went out and as I was thinking reverse the tree clocked down as I sat there
Faster Horses, Younger Women, Older Wiskey, More Money --- Tom T
