My wife left the ignition on....
#84831
07/06/08 02:34 PM
07/06/08 02:34 PM
Posts: 727 Falcon, CO
71pettyblue
Falcon, CO
...yesterday (at least 17 hours) on her '98 Durango, draining the battery, but that's not the half of it. I got the Durango to start with a jump from my Ram, but when I let go of the pedal, the engine dies. I'm assuming that the fuel pump was damaged and the Durango does not have enough fuel pressure to idle?
Any thoughts?
Tony Retired Mopar Enthusiast
Re: My wife left the ignition on....
[Re: DaytonaTurbo]
#84834
07/06/08 02:42 PM
07/06/08 02:42 PM
Posts: 2,592 None
71rm23
None
When you leave the ignition on, the computer will only power the fuel pump for a couple seconds to prime the system, then shut the pump off. Pump won't run continuously unless the computer detects the engine is running.
Modern EFI cars often don't run well with a dead battery when boosted. Throw the battery on the charger for an afternoon then put it back in and start it up. I'll bet it'll run fine.
[Re: DarrenS]
#84835
07/06/08 02:42 PM
07/06/08 02:42 PM
71pettyblue
Falcon, CO
I'll charge the battery up, thanks for the tip guys.
[Re: 71pettyblue]
#84836
07/06/08 02:57 PM
07/06/08 02:57 PM
Posts: 3,380 KY USA
mopargem
KY USA
Happened to my Dakota once, it would hardly run. After disconecting battery for a few moments the computer reset itself and ran fine.
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F6 M6W 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
