Re: Help - usually have to start my RR from under the hood
[Re: RM21N0A]
#847970
11/07/10 02:29 PM
11/07/10 02:29 PM
Posts: 606 Montana
Yancy Derringer
Montana
When you say "it won't start" I assume you mean "the starter does not crank?"
Try actually troubleshooting it. Here's what I'd do. First, rig a test lamp with some long test leads so you can "get to stuff" and go to RadioSh** and buy a pack of clip leads Now this test lamp should NOT BE the kind you usually buy. rig one up with a STOP LAMP (turn signal) bulb. The reason you want a BIG bulb is so it will pull some current. This is important
Now EVERYTIME you start the car--until you find the problem, perform a test until you eliminate the problem. Open the hood before you insert the key, and if it won't crank, you can have a test rigged to see what you find
Because the car (evidently) runs OK, we can assume the ign switch is GETTING power. But there's a "long ways" OUT of the switch to the starter
Here's the basic path:
The switch itself could be bad in the start position
the connector on the switch could be loose/ corroded
the connection through the bulkhead connector could be loose/ corroded
From the bulkhead connector, the ign switch feeds one push on connector on the start relay
If this is an original '70 stick car, it had/ has a clutch safety switch.
So the relay should have FOUR terminals, just like a Torqueflite
So the second push on terminal of the start relay goes BACK through the firewall, to the clutch switch. (I don't remember---it may go through the bulkhead connector, or may be a separate wire through a grommet.
The above wire goes to the clutch safety switch.
The clutch safety switch, if still there, may be out of adjustment or defective
Last, the second terminal of the clutch safety switch goes to ground
AND the start relay could be bad (internal damage, rust, burned contacts)
OK, first thing to do is find out if you are getting power to the start relay FROM THE KEY
So, once again, instead of "jumping in" and twisting the key, "assume" that it won't crank and set up a test.
My (poor) diagram shows the ign sw. wire feeding the start relay is yellow. Pull this off, clip your test lamp on there to ground, and twist the key. If the light comes on, you MAY have power OK
If not, you have already isolated the problem from there---through the bulkhead--to the ign switch.
IF you DO get a light, hook the yellow back up, and pull loose the second push-on terminal.
Hook the lamp from the exposed terminal on the relay to ground, and twist the key. Get a light, then OK so far.
So is it the clutch switch?
Go inside the car, clip the test lamp on the un--grounded terminal of the safety switch, the other clip of the lamp to ground.
DO NOT push in the clutch. Twist the key, you should get a light. NOW push in the key, the light should go out, and the starter should crank.
You may have to repeat these a couple of times---if the trouble is not showing up.
Another thing to try is to dig around up by the column I ?? believe ?? that you can acess the ignition switch connector down at the column. If you can, probe the yellow (start) wire there with your lamp to ground when twisting the key.
These are simple circuits, guys. The biggest problem is figuring a way to connect your lamp, and to keep at it.
You can buy a lOT of parts and throw at the thing, then find out it was a simple wire end broke/ corroded, etc.
[Re: RM21N0A]
#847971
11/07/10 02:42 PM
11/07/10 02:42 PM
Posts: 9,312 SoCal
68HemiB
SoCal
You should consider diagnosing the actual problem, instead of throwing parts at it. The good news is that your intermittent problem will manifest itself often enough for you to troubleshoot (it's the once-in-a-blue-moon intermittent problems that are a bear). Arm yourself with a volt/ohm meter and a wiring diagram. A good online source for wiring diagrams is MyMopar.com. Given that arcing the starter relay with a screwdriver works, you already know that the starter, battery, and large wires connecting them are not the culprit. Your manual transmission 1970 Plymouth Satellite needs two other things for the starting system to function properly: 1. A ground through the clutch/neutral safety switch [probably dark green]. 2. Power from the ignition switch when in the start position [probably yellow]. Check for continuity to ground (ohms setting on the V-O meter) at the appropriate connection at the starter relay when you stomp on the clutch. Lacking the ground, chase that circuit (firewall connector, switch, switch's ground). Check for power (dc volts setting on V-O meter) at the appropriate connector on the starter relay when the ignition is in start position. Lacking power, chase that circuit (firewall connector, ignition switch connector, ignition switch itself). Good luck. Electrical is not voodoo, contrary to what some might believe.
Down to just a blue car now.
[Re: RapidRobert]
#847973
01/20/11 05:38 PM
01/20/11 05:38 PM
Posts: 531 Virginia
RM21N0A
Virginia
Well, right after creating this thread, problem went away - hasn't come back yet, but it probably will. I do appreciate the suggestions though - so I thought I'd go ahead and reply. Better late than never. Quote:
Yup - that's what I meant to say.
Turn the key - absolutely nothing would happen.
So I would start it with my screwdriver between the 2 studs on the starter relay.
After driving a while and getting it warmed up, I'd shut it off, then it would start right back up with the key just like brand new.
It's not the clutch safety switch - it was disconnected when I bought the car in 04 and I've always liked it that way. The wire is just grounded to the firewall. I figure if I want to start the car without touching the clutch pedal, that should be my choice.
I guess I was hoping that the fact that it always works right when hot would mean something to someone who would know exactly what the problem was - probably just means a loose connection somewhere.
Hey, Road Runner bro, Road Runner......Satellite would be RL, or RH, or RP, or something, etc., etc......
I know I should have dug out the old Volt-Ohm Meter by now, or rigged up a test light, but starting it with a screwdriver hadn't really bugged me enough yet.
Also, thanks RapidRobert for the suggestion to clean all the connections - I've checked and cleaned all of them, but it didn't seem to help.
What I hope to do sometime this year is get the ignition switch out of the column and check those connections.
Seriously, thanks for the suggestions.
Now if VDOT would just stop putting down all that salt and chemicals and sand every time the weatherman says we're getting a few flurries so I can DRIVE IT AGAIN! It's been SIX WEEKS!
At least I can start it up and listen to it rumble every now and then.
