Fiberglass experts, help with hood
#847790
11/07/10 02:49 AM
11/07/10 02:49 AM
Posts: 1,018 Hazlet, NJ
440Satellite
super gas
super gas
Hazlet, NJ
I just picked up a cheap raceweight 6 pack hood for my Dusterand need some advice. I needed some hood clearence for running a taller intake and air cleaner and got a good deal on the hood, its a pin on using zdus fasteners and is a thin race weight hood from MAS. I'm looking into adding some extra reinforcement to the underside to stiffin it up. I was thinking about using the smallest aluminum square stock bent to the shape of the stock hood and making a square frame and fiberglassing it to the underside then adding an extra layer or 2 of fiberglass to the entire underside of the hood and scoop. Sound like a good idea or is there a better way?
Also the the back corners of the hood where it meets the corner of the cowl and fender are a little rounded off, not pointed like the factory, is there a good way to add some material to the corners to make it fit better? Is this posible and how would I go about adding to the edge of the hood?
Any advice would be greatly appriciated. I really havent done much fiberglass work but I pride myself on learing and doing new things, love the challenge and it always comes out great once I do some reserch and dive in . Any fiberglass experts out there that can share some tips on this project? Thanks
Butch
1972 Duster
318 4 speed
1958 392 Hemi engine
waiting to be built!!!!!
Re: Fiberglass experts, help with hood
[Re: dOc !]
#847792
11/07/10 09:32 AM
11/07/10 09:32 AM
440Satellite
super gas
super gas
Hazlet, NJ
Ok I'll take a picture of the underside today.
Butch
1972 Duster
318 4 speed
[Re: crlush]
#847794
11/07/10 01:08 PM
11/07/10 01:08 PM
440Satellite
super gas
super gas
Hazlet, NJ
Looks like they used a strip of cardboard fiberglassed in but I want something a little stiffer. Heres a picture of the underside. I was thinking about adding the aluminum strips about 2-3 inches in from the edges and then making the entire hood a little thicker with an extra couple layers of mat. I'm going to take out the plexiglass that partially covers the scoop hole but I might add something simmilar cut to fit my air cleaner, seems like a good idea to really force the air in. So what do you think?
Butch
1972 Duster
318 4 speed
[Re: 440Satellite]
#847795
11/07/10 01:09 PM
11/07/10 01:09 PM
440Satellite
super gas
super gas
Hazlet, NJ
And heres the corners as I mentioned...
1972 Duster
318 4 speed
[Re: Boise Chall]
#847798
11/07/10 01:54 PM
11/07/10 01:54 PM
440Satellite
super gas
super gas
Hazlet, NJ
So doing it that way your actually making u channel fiberglass suports, never thought of that, good idea.
Out there looking at it again, I'm thinking about doing away with the zdus fasteners and running 4 pins in the corners. I was thinking about forming some aluminum angle stock to the contour of the fender tops and mounting them on the inside of the fenders and along the top of the back cowl area making a ledge on 3 sides for the hood to sit on to keep the shape. Then adding a 2 or 3 inch strip of flat aluminum stock along the underside in line with the pin mounting locations. Basically have a long strip on each side of the hood fiberglassed in, down the entire length of the hood on the sides so that the front and rear pins would both go through the same strip of aluminum for added strength.
Starting to think that the zdus fasteners may be a real pain for a street car.
Dont know if I explained it very good, but get the idea? Any thoughts?
Butch
1972 Duster
318 4 speed
[Re: dOc !]
#847803
11/07/10 05:18 PM
11/07/10 05:18 PM
440Satellite
super gas
super gas
Hazlet, NJ
![](/ubbthreads/images/graemlins/thumbs.gif) Gotcha, makes sence!!!! Weight is not an issue as its not a race car, more interested in duabillity and strength. Dont want it so heavy that its a pain to lift on and off, but no mater what it will still be way lighter then the stock hood. Butch
1972 Duster
318 4 speed
[Re: dOc !]
#847805
11/07/10 08:46 PM
11/07/10 08:46 PM
440Satellite
super gas
super gas
Hazlet, NJ
If I did, it probably would change the contour. So I was thinking about taking some 2x4's and making a square and shaping them to the contour of the top of the stock hood, so one down each side and one in front and back. It would take some work to shave them down to fit the contour but I figured I could them use that frame to set the fiberglass hood upsidedown on and it would be the same as the stock hood, then fiberglass. Sound like a decent idea?
Butch
1972 Duster
318 4 speed
[Re: 440Satellite]
#847806
11/07/10 09:08 PM
11/07/10 09:08 PM
Posts: 30,536 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
THERE you go ...with the 2x4's .... ![](/ubbthreads/images/graemlins/thumbs.gif) but if that flexes THIS much ...THAT is plain WRONG ![](/ubbthreads/images/graemlins/down.gif) OK ... get some CONDUIT(or sim-size alum tube) and BEND-same to fit the underside of the hood on the OUTside of that existing bracing. THEN put a tube in side-to-side just in front of the scoop. 'GLASS-in(1.5 oz mat) ...and you should be good-to-go.
[Re: Boise Chall]
#847808
11/07/10 09:31 PM
11/07/10 09:31 PM
dOc !
Florida STAYcation
I've seen them come out of the box brand new with one rounded corner and one square corner and none of the glass looked chipped. almost like they made it that way.
VERY TRUE ... but what happened is the FG company probably stored the mold ON THE TIPS and wrecked the mold themselves. Some are also FAMOUS for grinding the "flash" off of the finished-part IN THE MOLD ...and then THIS reduces the size of the mold ...and every other part that comes out of that mold.
THIS is why all the molds I made had wood or metal bracing that would extend past the mold so it would keep the mold off the floor.
You would be surprised on how many FG companies do NOT do this ... ![](/ubbthreads/images/graemlins/shruggy.gif)
It makes working on the mold, prepping the mold, the gel-coat-process, roll-out of the main laminate, the bracing process ....sooooo much EZier.
But they can butter-their-bread as they see fit... ![](/ubbthreads/images/graemlins/smoke.gif)
[Re: dOc !]
#847809
11/07/10 10:46 PM
11/07/10 10:46 PM
440Satellite
super gas
super gas
Hazlet, NJ
Doc, Thanks for the advice, much apriciated. One more question for you, if I remove the zdus fasteners and put a fresh layer of fiberglass on the underside, can I just fill the holes where the fasteners were on the top of the hood with fiberglass filler? And with the tubing for bracing, should I weld the center support to the side tubes or just glass them in, would it add anything to weld it, making one peice?
Also I read about using foam pipe insulation cut in half and glassing it to the underside. Would the metal be a better option or would that work also?
Thanks for everything, time for some fun!!!!
Butch
1972 Duster
318 4 speed
