Re: Input on launch, video attached [Re: sshemi] #845523
11/06/10 04:11 PM
11/06/10 04:11 PM
Pennsylvania, USA
Big_Fish Offline OP
Big_Fish  Offline OP
Pennsylvania, USA
if it aint spinning why would you wanna adjust the suspension???
Replace converter and then start all over again.
When I got the new shocks I had taken it to a suspension shop to get a weight & balance and find the CG. They tweaked it to get it where it is now. I changed the shock settings a little to what your are seeing.
Next question which is why I haven't pulled the trigger... What company for a great converter? Can I get some input for top 3? COAN, Dynamic, etc.
Re: Input on launch, video attached [Re: Big_Fish] #845524
11/06/10 04:57 PM
11/06/10 04:57 PM
Down South
DaKuda Offline
DaKuda  Offline
Down South
Turbo Action ONLY for me...
Re: Input on launch, video attached [Re: DaKuda] #845525
11/06/10 05:30 PM
11/06/10 05:30 PM
sweden
sshemi Offline
sshemi  Offline
sweden
dont have much experience with this but i think it would be hard for any one of them to get it 100% right the first time.
Re: Input on launch, video attached [Re: DaKuda] #845526
11/06/10 06:22 PM
11/06/10 06:22 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Me Too!!!
If you like drag racing, support your local track.
Re: Input on launch, video attached [Re: CHAPPER] #845527
11/06/10 11:10 PM
11/06/10 11:10 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Me Too!!!
X3
Re: Input on launch, video attached [Re: racerx] #845528
11/07/10 12:07 PM
11/07/10 12:07 PM
tboomer Offline
tboomer  Offline
I am sending my converter to Kenny Ford at PTC for a rework...They have always treated me well and have great customer service!!
Re: Input on launch, video attached [Re: racerx] #845529
11/07/10 12:16 PM
11/07/10 12:16 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Me Too!!!
X3
x4
Re: Input on launch, video attached [Re: Big_Fish] #845530
11/07/10 12:34 PM
11/07/10 12:34 PM
Phoenix,Az.
hemicop Offline
hemicop  Offline
Phoenix,Az.
If IT WERE ME---since you already have a 5500 stall converter (good, I hope) I'd first make sure I was leaving while up against the converter. I had a similiar equipped but MUCH heavier car & would 60ft in the 1.30-1.33 range. Don't know what tire pressure you're running, but we almost always ran around 9psi. one way or another I'd find some way to loosen up that front end & for that matter, later on, if you have no luck, perhaps even lighter rear springs so as to the allow the back end end to squat---it looks like your back-half isn't working either. For me, if the car "pitches", your suspension isn't working evenly which could cause or is a sign of another problem---just MY , but hey!----you asked...
Re: Input on launch, video attached [Re: Big_Fish] #845531
11/07/10 12:35 PM
11/07/10 12:35 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
Im surprised nobody mentioned rear gear. Isnt a 4.56 with 33" tires to high? I would think thats why mph is on the high side, but 60' is slower. Dont most cars with big tires run a taller gear?
Re: Input on launch, video attached [Re: moparguy7074] #845532
11/07/10 04:29 PM
11/07/10 04:29 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Why would you want more susp travel if it aint spinning??
All other movement eccept forward will slow the 60 down.
Besides i dont know if your 60 is bad at all?
Besides pulling a little to the right, that chassie looks sorted out to me.
Re: Input on launch, video attached [Re: moparguy7074] #845533
11/07/10 04:36 PM
11/07/10 04:36 PM
Pennsylvania, USA
Big_Fish Offline OP
Big_Fish  Offline OP
Pennsylvania, USA
I was thinking of putting 4.88's when I went from 32 to 33" tires. I run 10.5 lbs of air pressure in the tires. I think this winter I'll start with a new converter, then front coil overs to get more travel in the front end and then see what happens at the track before I change anything else.
Re: Input on launch, video attached [Re: Big_Fish] #845534
11/07/10 04:41 PM
11/07/10 04:41 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I run 513s with a 32: tire
Re: Input on launch, video attached [Re: Quicktree] #845535
11/07/10 04:49 PM
11/07/10 04:49 PM
sweden
sshemi Offline
sshemi  Offline
sweden
you should be turning about 7000 rpms at the line now right? Thats calculated with 8% slipp in verter.
Doesnt seem very wrong for me.
Going to 4.88 wont change much. your mph will probably go up a little more.
