1/4 mile ET difference from 727 to 5 speed... #845325
11/03/10 08:11 PM
11/03/10 08:11 PM
Cleveland
sunroofgtx Offline OP
Cleveland
Everything else stays the same. 4.10 gear. 3500 stall now, not sure what the 5 speed ratios are. 4100 lb, 10.89 @ 126 best. Slicks are not now and will not be used, only sticky M/T Drag Radials. Not a race car, just a streetcar. What are your thoughts? Thanks.
Oh ya, and thought on the guy shifting, just call him Polish Power Putski, the Manual Macho Man. I might be asking Mike "the man" Laboda for set up pointers.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: 1/4 mile ET difference from 727 to 5 speed... [Re: sunroofgtx] #845326
11/03/10 08:14 PM
11/03/10 08:14 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
stick 11.1
Mopar Performance
Re: 1/4 mile ET difference from 727 to 5 speed... [Re: sunroofgtx] #845327
11/03/10 08:14 PM
11/03/10 08:14 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I would call the company selling the 5 speed and ask them what they think of using it for drag racing. Liberty trans?
Re: 1/4 mile ET difference from 727 to 5 speed... [Re: sunroofgtx] #845328
11/03/10 08:14 PM
11/03/10 08:14 PM
ohio
all spooled up Offline
ohio
whats the first gear ? i would think with a lower first gaar it will be faster
Re: 1/4 mile ET difference from 727 to 5 speed... [Re: sunroofgtx] #845329
11/03/10 08:16 PM
11/03/10 08:16 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Wow two posts already
What tranny are you thinking about? A Passon unit
Gus
64 Plymouth Savoy
Dana 60
Re: 1/4 mile ET difference from 727 to 5 speed... [Re: sunroofgtx] #845330
11/03/10 10:39 PM
11/03/10 10:39 PM
South Carolina
a408swinger Offline
mopar addict
a408swinger  Offline
mopar addict
South Carolina
We did just the opposite on my buddys truck. We went from a 5 speed in his 95 Dakota with a 414" small block to a 904 with a good 10" converter. The truck ran a best of 11.9x @ about 115 mph with the 5 speed and dropped to a best of a 10.80 @ 123 with the 904. Just couldn't shift if fast enough with a regular hydraulic style clutch. Maybe with a pro shifted tranny it would be a better comparison but with a regular clutch assisted type 5 speed the auto with a good converter will be significantly faster from what we have found.
Re: 1/4 mile ET difference from 727 to 5 speed... [Re: a408swinger] #845331
11/03/10 11:10 PM
11/03/10 11:10 PM
Arizona
Chris'sBarracuda Offline
Arizona
This is really a cool trans. Even has a paddle shift option..
http://www.tciauto.com/Products/TC-%27Street%20Transmissions%27-4.aspx
Chris..
Re: 1/4 mile ET difference from 727 to 5 speed... [Re: Chris'sBarracuda] #845332
11/04/10 12:01 AM
11/04/10 12:01 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
At 4100 lbs. you better be prepared to buy an expensive clutch set up or up grading to some super duty other drive train parts.
Re: 1/4 mile ET difference from 727 to 5 speed... [Re: rowin4] #845333
11/04/10 09:52 AM
11/04/10 09:52 AM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
Not really....my dad runs a 4000lbs RR with a centerforce DF and around 550+hp. Just let the tires spin a few revolutions at the line,...the rest works fine. Stock 23 spline A-833!
Re: 1/4 mile ET difference from 727 to 5 speed... [Re: rowin4] #845334
11/04/10 09:57 AM
11/04/10 09:57 AM
Cleveland
Cleveland
I'm getting ready to take it down to Keisler's for the first install of his new Borg Warner HD American Made 5 speed. It won't be race-specific, but he knows I'll be rowing it a couple of times a year !! Wow, Chris.. thats a nice tranny. I'll find out the ratio's today. Maybe Gene can chine in.
Re: 1/4 mile ET difference from 727 to 5 speed... [Re: sunroofgtx] #845335
11/05/10 02:36 PM
11/05/10 02:36 PM
Tennessee
Keisler Sales Offline
Tennessee
The ratio's are 2.80,1.99.1.33 1.0 and .67
Happy Rowing!
Keisler Engineering www.keislerauto.com
#1 Choice of Overdrive Transmissions with Over 14,000 Sold
Re: 1/4 mile ET difference from 727 to 5 speed... [Re: sunroofgtx] #845336
11/05/10 02:38 PM
11/05/10 02:38 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
my guess is the car will slow down at least 3-4 tenths with the 5-speed vs the auto.
Scott
Re: 1/4 mile ET difference from 727 to 5 speed... [Re: sunroofgtx] #845337
11/05/10 04:37 PM
11/05/10 04:37 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Chiming in:
I see you like abuse and mediocrity, good luck...
Re: 1/4 mile ET difference from 727 to 5 speed... [Re: sunroofgtx] #845338
11/05/10 04:43 PM
11/05/10 04:43 PM
I don't think you will find a drag radial tire that will work fine on a stick shift car with any power My choice would be a high traction street bias ply tire like the M/T ET Streets(big ones ) or a similar Hoosier street bias ply tire. I have ran both the M/T Et Street Radials and ET Street bias plys on my street car with the automatic, the bias plys work way better on the street than the radials do I had a stick shift low power(ran in the high 11s) 440 six pak Challenger, no traction with BFG drag radials, had to slip the clutch to prevent frying the tires Once the radials break loose they spin up really fast and won't recover unless you let off or shift into the next higher gear, at least on my cars The radials are faster than the bias plys on a good track, not so on a bad track
Re: 1/4 mile ET difference from 727 to 5 speed... [Re: sunroofgtx] #845339
11/05/10 05:01 PM
11/05/10 05:01 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Who cares if it slows down, the 5-speed will be way more fun, especially on the street. I have no regrets putting a 4-speed in my Dart.
Re: 1/4 mile ET difference from 727 to 5 speed... [Re: dustergirl340] #845340
11/05/10 05:15 PM
11/05/10 05:15 PM
cleveland Ohio
mloboda Offline
mloboda  Offline
cleveland Ohio
My sentiments exactly. The car will be mostly street driven. Even if it slows down a bit, and I'm not sure that will be true, you will have a hundred times more fun with the car. There is no way to compare the direct-coupled feeling of a manual transmission to the "slushy" feeling of a converter.
When you go cruisin', you won't be able to wipe the smile off your face!
Re: 1/4 mile ET difference from 727 to 5 speed... [Re: mloboda] #845341
11/05/10 05:50 PM
11/05/10 05:50 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I agree, I say go for it! I usually don't believe in slowing cars down but I think you'll have a blast with the stick shift. I also agree with the QTP's or ET Streets, drag radials will be a big challenge.
Re: 1/4 mile ET difference from 727 to 5 speed... [Re: ProSport] #845342
11/05/10 06:05 PM
11/05/10 06:05 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Im not a pureist by any stretch....but dont cut on that damn car
Re: 1/4 mile ET difference from 727 to 5 speed... [Re: joshking440] #845343
11/05/10 07:21 PM
11/05/10 07:21 PM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
Its a little late for that, Its a RACECAR !! inside joke for Rick.
The car has wheel tubs and a cell
Re: 1/4 mile ET difference from 727 to 5 speed... [Re: 10secGTX] #845344
11/05/10 07:56 PM
11/05/10 07:56 PM
Rittman Ohio
Rittman Ohio
Rick I am a little worried about the choice of gearbox with the torque and weight of your car
I sure hope you got some sort of warranty with that box because I know when your car hooks it will be the PURPLE PUNISHER on that T45 even with the internal upgrades.
As far as cutting the car up,it's a "keisler conversion" "no cutting required"
I wish you luck my friend IMHO you need a weaker(custom)clutch or a stronger tranny been there done that...
Gus
64 Plymouth Savoy
Dana 60
