Re: Cam installed centerline question
[Re: 426runner]
#844366
11/02/10 06:09 PM
11/02/10 06:09 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
it will run better...lol
you are 3 degrees advanced...advancing the cam with help the low end performance...increase cylinder pressure by closing the instake valve sooner..
Advancing the camshaft means that you are starting the opening and closing process sooner in the cycle. It generally improves low-speed torque and mid-range power while sacrificing top-end hp. Conversely, retarding the cam detracts from low- and mid-range power in order to help top-end power. Generally, moving a camshaft a couple of degrees will not make dramatic changes to the engine's power curve
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Stanton]
#844369
11/02/10 09:00 PM
11/02/10 09:00 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Your engine will be retarded !
The intake valve opens later and closes later. Since it closes ABDC that's a hair less compression the motor will make. Likewise the exhaust valve will open sooner, releasing combustion pressure sooner. All this equates to a loss of power.
You have it backwards. If the intake valve reaches peak lift earlier at 105* ATDC vs 108* ATDC
Then it is indeed advanced and not retarded.
For the OP, if thats where your at. Thats not a bad ICL area. IMO 101* to 106* for alot of engine combos is a good general ICL. mike
[Re: 426runner]
#844371
11/02/10 09:54 PM
11/02/10 09:54 PM
RapidRobert
yes it's confusing as a smaller # ie 105 vs 108 means sooner (advanced) as 5 o'clock is sooner than 8 o'clock. the intake valve reaches peak lift at 105 deg past TDC compression (which is sooner) than if it reached it at 108 deg past TDC compression (& therefore closes sooner). As said it shifts the power band lower & reduces the valve to piston of either the intake or ex valve (I forget which one). Cams I've advanced (street) which you'd be doing (to 105) have always benefitted from it (more torque)
[Re: RapidRobert]
#844372
11/02/10 10:02 PM
11/02/10 10:02 PM
Posts: 1,200 UK
602heavy
UK
yes it's confusing as a smaller # ie 105 vs 108 means sooner (advanced) as 5 o'clock is sooner than 8 o'clock. the intake valve reaches peak lift at 105 deg past TDC INDUCTION stroke (which is sooner) than if it reached it at 108 deg past TDC INDUCTION stroke (& therefore closes sooner). As said it shifts the power band lower & reduces the valve to piston of either the intake or ex valve (I forget which one). Cams I've advanced (street) which you'd be doing (to 105) have always benefitted from it (more torque)
[Re: GomangoCuda]
#844375
11/03/10 03:13 PM
11/03/10 03:13 PM
Posts: 1,371 Costa Mesa, CA
chache876
Costa Mesa, CA
Heres a somewhat related question about cam timing...
If I have an adjustable timing chain with multiple keyways on the crankshaft gear, and they are marked 0, +1, +2, +3, -1, -2, -3, etc...
Lets say I have a lobe separation angle of 106*
If I set the timing gear so that it is in the +2 slot, does that mean I am advancing the camshaft 2 degrees so that its now 104* or does that mean that I am adding 2 degrees to the 106* number? 106+2=108?
[Re: chache876]
#844376
11/03/10 03:40 PM
11/03/10 03:40 PM
Posts: 1,200 UK
602heavy
UK
+ advance - retard
'lining up the dots' is a no no , the only accurate way would be to use a degree wheel , some of those crank/cam gears are not always accurate.
[Re: GomangoCuda]
#844377
11/04/10 03:24 PM
11/04/10 03:24 PM
Posts: 1,396 Mass
dgc333
Mass
double it and divided by two
How long has it been since you had a basic math class?
I know exactly what I said, in my 30+ years as an engineer I have found that sometimes it helps to make things clear to state the obvious. I could have just said; "straight up centerline = lobe seperation angle" but I wonder how many more folks will remember why that is true because I added the silly little math expression.
[Re: dgc333]
#844378
11/04/10 05:27 PM
11/04/10 05:27 PM
RapidRobert
I'm w you here as cam theory is (sort of) Greek to me & I need it (the obvious) spelled out so I can grasp it.
[Re: chache876]
#844379
11/04/10 06:51 PM
11/04/10 06:51 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Lobe seperation angle is not the installed centerline. Lobe sep angle is ground into the cam and cannot be changed. The installed centerline is where the cam grinder reccomends to put the intake centerline for best performannce. Ron
[Re: 426runner]
#844381
11/11/10 02:33 PM
11/11/10 02:33 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Another related question... It is always recomended to check the installation of the cam for the proper centerline as called for by the manufacturer. Most all write-ups or videos that show the process end up with the CL coming out correct. Mine didn't. My installation calculated out to 105 instead of 108 like the card said it should. Why would this happen? What factors could contribute to the cam not being as the manufacturer says it should be out of the box? And yes, there were 2 of us there during the degreeing process and we did it over and over and came up with the same 105 every time.
Timing chain set variances, cam being ground slightly off, could be a couple issues to change the installed centerline.
[Re: RobX4406]
#844382
11/11/10 02:52 PM
11/11/10 02:52 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
It's called the stacking effect. the key way on the crank may be of a bit. the key way in the bottom gear may be off a bit, the dowel hole in the top gear may be off a bit and the dowel placement in the cam may be off a bit as these things are less than perfect. sometimes it stacks up to 10 or more degree's off. I would leave your cam where it is you will like it with a tad more advance!
