Re: Loosing lash on one valve........ Ever had it?
[Re: pittsburghracer]
#843298
11/07/10 12:37 AM
11/07/10 12:37 AM
Posts: 417 reynoldsburg,ohio
poppaj
reynoldsburg,ohio
John, If you put all new lifters in I would go with Lunati. The link bar setup is a ton better than the Comps. I have had bad luck with their lifters. The Ferara valves are nice, that is what I put in about all my builds. Inspect the cam bearings as well to make sure you don't have one spinning with the cam it will cause a valve to tighten as well. Good luck with it. poppaj
AA/NSS 65'Coronet "Whompin Wedge" Pop & Son Performance 557" B-1 power John Holt Chassis
