Re: How Much Converter?
[Re: Quicktree]
#842225
10/30/10 10:04 PM
10/30/10 10:04 PM
Posts: 2,541 PA
moparacer
PA
Just tested the new engine in my old Duster today. Went 10.58 @ 122 today and it has 4.10 gears 28X10 mickeys with 88 circumference and crosses the line at 6700. Shows 10.45 percent slip. Converter flashes to 5400.
Close to the same engine specs as you and we don't run a low gear set and I am a couple hundred lbs lighter then you are.
Could tighten the flash up but if you are bracket racing sometimes its better to be on the loose side.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: 77DragracerR/T]
#842227
10/30/10 10:27 PM
10/30/10 10:27 PM
Posts: 2,541 PA
moparacer
PA
1.40 on this pass. Forgot to add I run the 2.45 first gear in this 904 too. Would be too hard to hook consistently with the 2.76. http://img185.imageshack.us/i/duster004.mp4/
