Re: best way to get paint off glass?
[Re: dangina]
#841715
10/29/10 09:21 PM
10/29/10 09:21 PM
Posts: 3,054 USA
b54406barrel
USA
[Re: Challenger 1]
#841722
10/29/10 11:18 PM
10/29/10 11:18 PM
Posts: 3,054 USA
b54406barrel
USA
Razor blade.
A brand new one, change them often and they will do a great job.
Guess I was pretty brief with my answer. Yes, buy a box of safety blades & if it's overspray on all the windows, figure on using 15-20 or so of 'em. Dab one side with a perm. marker so you don't flip it. Way-way back when I was a painter, brass or bronze wool was very good but urethane's don't come off quite as easy as lacquer & dulux did!
[Re: b54406barrel]
#841723
10/30/10 01:05 AM
10/30/10 01:05 AM
Posts: 8,395 Highland, MI.
Sunroofcuda
Highland, MI.
Spray Windex (or whatever glass cleaner to act as a lubricant) & use a clean razor blade - nothing with rust or dirt on it. The glass is harder than the razor blade so you can't scratch the glass with it. Paint comes right off. DO NOT use a scotch brite pad or anything similar! (DAMHIK)
