Re: NORMAL COMPRESSION??? [Re: polyspheric] #841591
10/30/10 12:36 PM
10/30/10 12:36 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
...out the exhaust valve" ???????
Which cam is that where the exhaust valve is open during the compression stroke?
I think you failed to understand my post. Obvously none, that's why there are the question marks. I'm quoting the other poster.
Re: NORMAL COMPRESSION??? [Re: BSB67] #841592
10/30/10 05:09 PM
10/30/10 05:09 PM
New York
polyspheric Offline
polyspheric  Offline
New York
You're right, sorry, yes I understood your comment to mean "Whaaaa?".
Was referring to prior comment.
Boffin Emeritus
Re: NORMAL COMPRESSION??? [Re: polyspheric] #841593
10/30/10 05:24 PM
10/30/10 05:24 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
But, FWIW, the Calulater that Dodgem posted was Happy about by 20# PSI for my Combo. But with your engine specs, it was almost right on. mike
it's not even close for my motor and as stated my leak down is less than 3% so I know it is sealed up well I also know someone that there roundy round motor is well over 600hp and only 165 cranking compression.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: NORMAL COMPRESSION??? [Re: dusturbd340W5] #841594
10/30/10 05:34 PM
10/30/10 05:34 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I run a big overlap pump gas cam, I get 150 cranking compression. I put one gallon of 110 race gas in the tank when I race but don't need to. I've used lawn mower gas to drive to a local car show before, and still goes 9.80's.
If I go E85 this winter, it will get a better cam for performance.
Re: NORMAL COMPRESSION??? [Re: Labratt] #841595
10/30/10 05:44 PM
10/30/10 05:44 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
BTW...how important is it to have the butterflies partially open,as Hardcore suggests?
LABRATT, I feel it's very important. With the throttle closed can cause a restriction and produce lower than normal cranking compression readings
My personal preferance is to set the carb @ WOT when testing. Usually I'll hold it open with a wire or use the return spring to hold it FWIW.
Don't forget to return the throttle closed before you start the motor again
Re: NORMAL COMPRESSION??? [Re: roadhazard] #841596
10/30/10 07:16 PM
10/30/10 07:16 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I often just take the carb off! then no fuel gets squirted in.
Re: NORMAL COMPRESSION??? [Re: Dodgem] #841597
10/30/10 08:52 PM
10/30/10 08:52 PM
Kissimmee Fl.
Kissimmee Fl.
yep carb wide open or removed and all 8 plugs removed and a battery charger hokked up and running is how I do it.
Re: NORMAL COMPRESSION??? [Re: polyspheric] #841598
10/30/10 09:05 PM
10/30/10 09:05 PM
UK
602heavy Offline
602heavy  Offline
UK
large overlap cams bleeding compression
How exactly does this happen?
My thoughts exactly , overlap has no bearing on compression whatsoever.
Re: NORMAL COMPRESSION??? [Re: roadhazard] #841599
10/30/10 09:49 PM
10/30/10 09:49 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
So Greg..my readings would have been higher if I opened the butterflies on the carb??
Re: NORMAL COMPRESSION??? [Re: Labratt] #841600
10/30/10 11:43 PM
10/30/10 11:43 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Always.
Boffin Emeritus
Re: NORMAL COMPRESSION??? [Re: polyspheric] #841601
10/30/10 11:51 PM
10/30/10 11:51 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Can't say with certainty but I also forgot to post as stated above "Remove ALL Spark Plugs"
p.s. got your PM & I'll get back with you on that
Greg
