Hi
I attached a view of my question also
- does anyone know what the diameter should mic at for the lower sleeve bearing on the tube,may not replace if its good still.
- there is a seal that sits above the lower bearing, mine crumbled when disassembled. Is there a part supplier or a DIY method of replacing.
Thanks Moparts
6273998-SteerColumn.pptx (72 downloads)
