Will a 904 tranny fit behind a 360? #840246
10/27/10 03:13 PM
10/27/10 03:13 PM
MN
Skid_Demon Offline OP
MN
Greetings, I am installing a 360 from a 1978 Ram Charger into a 47 Dodge pickup. Installed a K-frame from a F-body in the 47. Replaced the stock 4:88 rearend with an 8.75 from a 1964 B-Body. I got a 727 (4x4) and torque convertor with the engine. I found a low mile 904 from a mid 70's Chrysler that was behind a 318. I understand the 318 is internal balance, 360 external. So, will a 904 with the 727 touque convetor fit behind the 360? This is my first attempt at such a project, so some/any advice would be helpful. Thanks.
Re: Will a 904 tranny fit behind a 360? [Re: Skid_Demon] #840247
10/27/10 03:26 PM
10/27/10 03:26 PM
S.E. Wis
a4runer Offline
a4runer  Offline
S.E. Wis
I have one behind my 360 in my Dart with a 3500rpm
convertor works just fine bolt up swap.You can not use the 727 convertor you must use a convertor for a 904.
Re: Will a 904 tranny fit behind a 360? [Re: a4runer] #840248
10/27/10 03:29 PM
10/27/10 03:29 PM
Andrewh Offline
Andrewh  Offline
not sure I understood,
you want to use the torque converter from the 727 in the 904? and bolt that up to the 360?
I don't think that works.
pretty sure the torque converters are different between a 727 and a 904, but someone more knowlegable should be along to say.
Re: Will a 904 tranny fit behind a 360? [Re: Andrewh] #840249
10/27/10 03:38 PM
10/27/10 03:38 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
No way can you use a 727 converter in front of a 904 transmission.
Re: Will a 904 tranny fit behind a 360? [Re: Skid_Demon] #840250
10/27/10 03:49 PM
10/27/10 03:49 PM
MN
MN
Thanks for the info. I have the 727 and 727 torque convertor. It sounds like the 904 will fit. Sounds like I need a 904 torque convertor. Does the 904 torque converor need to come from a 360, or will one from a 318 fit? Does the internal/external balance just applies to flywheels if you have a manual tranny? Thanks again. Hope to have it on the road soon.
Re: Will a 904 tranny fit behind a 360? [Re: Skid_Demon] #840251
10/27/10 04:11 PM
10/27/10 04:11 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
If you run a neutral balance torque convertor, you will need a weighted flexplate.
Re: Will a 904 tranny fit behind a 360? [Re: burdar] #840252
10/27/10 04:43 PM
10/27/10 04:43 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
360 means you need an external balance in back.
904 means a 904 converter.
You can buy a 360/904 converter and get a neutral 904 flexplate.
You can buy a 360 (offset weight) flexplate and any 904 converter.
I don't think the stock 727 flexplate will work with a 904 converter (smaller bolt pattern).
Re: Will a 904 tranny fit behind a 360? [Re: RodStRace] #840253
10/27/10 07:33 PM
10/27/10 07:33 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
with that
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Will a 904 tranny fit behind a 360? [Re: RodStRace] #840254
10/27/10 08:58 PM
10/27/10 08:58 PM
Upper Midwest
Upper Midwest
Some 727's use the small flex plate. And most after market performance converters used the small pattern flex plate.
Re: Will a 904 tranny fit behind a 360? [Re: Skid_Demon] #840255
10/30/10 12:53 AM
10/30/10 12:53 AM
MN
MN
Good stuff. One more question. If I weld in the cross member mount on the frame for the 904, would I need to move it if I decided to install a 727?
Re: Will a 904 tranny fit behind a 360? [Re: Skid_Demon] #840256
10/30/10 01:25 AM
10/30/10 01:25 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
727 and 904 use the same crossmember and mount
Tony
70 AARCuda Vitamin C
