Re: Any A&A Hemi cross ram users ?
[Re: Hemi_K]
#840004
10/27/10 02:36 AM
10/27/10 02:36 AM
If the mopar cross ram doesnt fit, I doubt the a&a one will either.
[Re: Hemi_K]
#840006
10/27/10 09:17 AM
10/27/10 09:17 AM
Posts: 12,408 Taxes & Virus's R-US, NY
Dragula
I have a 472" Hemi (Had a Barton singleplane and with that the engine made 700hp).
That is probably the best intake we have ever run next to an Indy tunnel ram on basically the same size engine. We have gone a non-hooking 11.1's in a 4010lb Charger with a pump gas hemi and that intake. You not likely to beat that one with a cross ram or any other single plane any time soon.
The Indy mod man dual 4 single plane intake or a Stage V dual four hollowed out into a single plane are really the only choices I see that you really have. Stay away from the M1....Its better left in the trunk.
[Re: JohnRR]
#840010
10/27/10 11:07 AM
10/27/10 11:07 AM
Posts: 376 Helsinki,Finland
Hemi_K
Helsinki,Finland
The hp difference was 40. with the Barton intake there was a 1100 dominator and with the StageV there were 750 holleys and 800 Edelbrocks. both opening the same time. There was only a couple hp difference between the holleys and the edelbrocks. With the holleys the fuel curve was significantly better in the dyno...
Also a bit confusing to us was that the peak power was with the Barton intake at 6800 and with the stageV at 6100 remembering that there is now a roller cam which should give itīs peak power way higher ??
[Re: Hemi_K]
#840013
10/27/10 02:03 PM
10/27/10 02:03 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
No, not before I am satisfied with it...
...and the car was recently painted and not yet completely assembled.
You can't drive a dyno , if you don't want a scoop and it's a street car I really don't think you'll miss the 40 HP , are you comparing the entire dyno pulls or are you just stuck looking at the peak HP number ?
[Re: Hemi_K]
#840017
10/27/10 05:27 PM
10/27/10 05:27 PM
JohnRR
U.S.S.A.
I donīt recall we were talking about intakes with Barton when i ordered the cam so he propably thought that his intake will be used.
My goals ? beat that 701hp that the engine made before. Beat my 11,5 at the quarter.(it was with MHīs). Go as fast as possible keeping the car really streetable, cruisable, etc. Now, with Gear Vendors overdrive i hope it to be bearable in the highways too - little better mileage and less noice...
yes, there are and surely will be a couple faster guys than me. Jyrki (is he still active here ?) with his double turbo Vip is in the 7īs in the street D class. I guess I donīt beat him anytime soon...
yes jyrki is still here .
What was the 701HP combination ?
