Question about burnout technique
#839835
10/26/10 11:21 PM
10/26/10 11:21 PM
Posts: 1,221 Jarrettsville, MD
tywebb2
super gas
super gas
Jarrettsville, MD
I have always blipped the tires in the water box, rolled forward. Waited for the go signal from the track official then pump my brakes, hold the line lock, and hit the throttle with the car in 2nd gear holding it between 4K-5K. The problem I have is the rear end of the car always starts to slide to the left midway through the burnout.
Is there something I should be doing differently to eliminate this problem? I see guys go up there and smolder the tires and the rear of their cars don't move????
'72 440 Cuda 11.673 @ 115.91 w/1.663 60'
Re: Question about burnout technique
[Re: savoyracer]
#839837
10/26/10 11:32 PM
10/26/10 11:32 PM
Triple Threat
Renton Washington
Could be the track, the clutches going out in your rear end or you not getting on the throttle hard/fast enough.
[Re: Triple Threat]
#839838
10/27/10 09:00 AM
10/27/10 09:00 AM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
I gotta ask, whats the point of blipping the tires in the water box. Seems like all that is accomplished is throwing more water on the undercarrige of the car.
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
[Re: savoyracer]
#839839
10/27/10 09:28 AM
10/27/10 09:28 AM
Challenger 1
Cincinnati, Ohio
more wheel speed helps stop that problem
That's correct, you need more wheel speed to keep it straight.
[Re: HemiDart68]
#839840
10/27/10 11:07 AM
10/27/10 11:07 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
All it does is throw water up in the wheelwell so it can drip down onto the tire later. Just roll through the water.
[Re: tywebb2]
#839842
10/27/10 11:32 AM
10/27/10 11:32 AM
Posts: 341 Highland beach Fl
poisondart2
Highland beach Fl
Would depend on how big a tire you are using vs power. More air in the tire would get it spinning quicker ( wheel speed ) and I wouldnt blip it in the water.
[Re: poisondart2]
#839843
10/27/10 07:38 PM
10/27/10 07:38 PM
tywebb2
super gas
super gas
Jarrettsville, MD
I just always blipped the tires in the water because that is the signal the track official gave me. They always bring me up whirl their finger when I hit the water and then stop you in front of the water for the burnout. Based on the feedback I will make sure to roll through from now on.
I am running 28" ET Street Radials with 4.10 gears in the rear.
Is the verdict that I should be starting in 2nd with a quick shift to 3rd in order to get the wheel speed up vs. staying in 2nd like I have always done?
[Re: nss guy]
#839846
10/27/10 08:13 PM
10/27/10 08:13 PM
tywebb2
super gas
super gas
Jarrettsville, MD
If 3 seconds is all it needs then I know I am getting at least that before the rear starts to slide.
[Re: tywebb2]
#839848
10/27/10 08:27 PM
10/27/10 08:27 PM
Posts: 685 SW Ohio
AAR-B4
SW Ohio
Blipping the throttle is needed at some tracks. A 32" tire that's over 8 feet of rollout, some tracks might only have a couple of feet down. Blip'em. My
[Re: AAR-B4]
#839849
10/27/10 08:45 PM
10/27/10 08:45 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I think he only has a 28" tire. The tire will push a puddle of water ahead of it. Plenty of water on the tire.
Pull up ahead of water LIne lock second gear Stand on it When the engine rips put it in high If running a rev limiter on the line lock pump the button to release the line lock but keep the rev limiter working and when you feel the car start to lunge back out of the throttle. Pull on up and turn the top buld on and wait on the goof that can't figure out how to stage.
[Re: wheelsup68dart]
#839850
10/27/10 08:53 PM
10/27/10 08:53 PM
Posts: 73 Hartford,MI
goody340g
Hartford,MI
Another vote for no spinning the tires(blip) of the throttle. I roll completely out of water to where the previous burnout was done. Set line lock and don't be afraid to get the ball rolling, get on it strong and fast and be ready to go to third as the tach sees fit, 1 second or so in high gear, let off the button and stay in it till rear starts to grab and off the gas.
if they don't put down enough water ask for more. we are not bashful about stuff like that. i would not trust most burn box people, they don't care if you start in the same spot or not or if ur burnout is the same everytime. i've seen a lot of guys in door cars open the door and look for themselves.
[Re: Leon441]
#839851
10/27/10 08:56 PM
10/27/10 08:56 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
How 'bout these guys that think 10,000 rpms and so much smoke that nobody can see the 1 inch wheelie....or loose the motor?
The little old lady from Pasadena is back!
[Re: tywebb2]
#839852
10/27/10 08:59 PM
10/27/10 08:59 PM
Posts: 16,929 NC
440Jim
NC
One thing that can cause that is the caster on one front wheel is different than the other. And, IMO, the more positive caster the better.
I also agree that you should shift to high gear and get the wheel speed up.
There may be other causes...
[Re: tywebb2]
#839854
10/27/10 09:20 PM
10/27/10 09:20 PM
Posts: 315 Russiaville, IN
mopar376d
Russiaville, IN
A good "burn out box" guy will spray behind the box. No need to blip the tires you get the tire wet driving through.
Why does divorce cost so much?
Because it is worth it!!!!!
