Page 11 of 16 1 2 9 10 11 12 13 15 16
Re: Mercedes fan upgrade [Re: hooziewhatsit] #838390
03/05/11 06:21 PM
03/05/11 06:21 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Snow shouldn't be a problem.
Currently the fan has been running for half an hour at 15% in the office. It's barely louder than the computers we have running, and it still sucks a piece of paper to the front of the radiator
Edit: make that an hour it's been running
Now you need to run it at WFO for an hour and stay in the same room with it.
Keep your fingers, loose papers, and small woodland creatures away from the blade.
- Stu Harmon
Re: Mercedes fan upgrade [Re: feets] #838391
03/05/11 07:25 PM
03/05/11 07:25 PM
Andrewh Online content
Andrewh  Online Content
also you need to keep your controler set to pulls the trigger wire to 90 percent incase it fails over from the controler wire.
you don't want it to spin up to 100 percent if you lose control wire contact.
Re: Mercedes fan upgrade [Re: Andrewh] #838392
03/05/11 07:43 PM
03/05/11 07:43 PM
hooziewhatsit Offline
I'll have to see what happens if I drive the original trigger wire with 90%, and the other wire with the varying duty cycle.
On my current test board, I have a tiny relay that ties the original wire to 12v while the other wire controls the speed. To turn the fan off, I switch both inputs to ground.
Re: Mercedes fan upgrade [Re: hooziewhatsit] #838393
03/06/11 06:51 PM
03/06/11 06:51 PM
I've been talking with Andy through PMs about a way to use the stock sender, and have the controller move the needle on the temp gauge in the dash.
What I've found is...
With a solid state (constant) 5v voltage regulator on the back of the cluster, I can move the needle though its range of motion.
With the stock pulsing regulator, I can only get the needle to about 1/3rd on the gauge.
So, if you have a solid state regulator, you can hook the stock sensor into the controller board, which will use that to control the speed of the fan. Then, you hook the wire that used to go to the sensor, into the controller board, and the controller will move the needle to show the temperature.
It may just be easier to drill and tap a third hole in the intake
Re: Mercedes fan upgrade [Re: hooziewhatsit] #838394
03/06/11 11:42 PM
03/06/11 11:42 PM
well now all you have to do is figure out a cheap solid state VR for the instrument cluster.
Re: Mercedes fan upgrade [Re: feets] #838395
03/07/11 12:16 AM
03/07/11 12:16 AM
wow, I see what you mean about drilling a new hole.
I can try to build one for about 10 bucks.
diy regulator
buy an odd looking one for 30 bucks.
better than diy
or spend 50 on a high tech direct replacement.
direct replacement
or just use a drill and tap I have to put in another. OR I guess I could live without a gauge in the car.
Nah, will proably try to build my own.
so how soon for a prototype to try?
and did you see if you can drive both at 90 percent, the trigger and controler wires?
Re: Mercedes fan upgrade [Re: Andrewh] #838396
03/07/11 04:54 AM
03/07/11 04:54 AM
I have not seen if I can drive both wires at 90% and have it still run. I guess I'm not too worried about it. If all of a sudden it's on full speed all the time, there must be a break in the speed wire, or the controller is fried. Either way it warrants a look to see what's going on. The circuit will be able to drive it at 90%, or 100%, so I can figure it out later, as my current prototype can't do it.
ETA for another prototype... hmm...
I guess it depends on how much more we're going to change the design I know the circuit I need to control the speed of the fan and to read the temp sensor. I also have a circuit that will move the needle on the gauge in the dash. I think we have everything pretty well nailed down, so I could go ahead and order some circuit boards. The alternative is $100 for a development board, and build the entire circuit to make sure it all works.
Oh yea, Andrew, what are your thoughts on the dip switches I used on the boards I sent you? Too hard to switch/too annoying/easy enough?
Re: Mercedes fan upgrade [Re: hooziewhatsit] #838397
03/07/11 10:56 AM
03/07/11 10:56 AM
I agree, I think we have everything locked down now on features.
the kicker was the variable speed. Temp gauge was a nice to have.
Dip switches were okay. A little odd to have 2 and only one doing anything.
but since you really only set it once, it isn't a big deal.
I hope you are not out too much proto typing all this stuff.
you might try selling the other boards to people that don't care about variable speed.?
if is it cheaper than a 100 bucks to just build a set, I would consider that. since we seem to be there. BUT having done the testing thing for a while, I tend to be pessimistic about this sort of thing and believe we have another go around.
Re: Mercedes fan upgrade [Re: Andrewh] #838398
03/07/11 03:45 PM
03/07/11 03:45 PM
As my wife succinctly put last night, I can do the dev board for $100, fix any issues, then get circuit boards for another $100 ($200 total). Or, get circuit boards for $100, and either be done, or fix issues and get another set for another $100. So likely only $100, and maybe $200.
I'll start the new layout today and send it off when I can. It'll be another ~2 weeks for a prototype. I also agree that we seem to have all the features nailed down. At this point it's just software to logically control the speed.
The new boards will probably have another dip switch or two on them to indicate GM or stock mopar sensor and whatever else I come up. Will probably include a switch to disable variable speed?
I'll probably make the other boards available at a pretty good discount for those that don't want variable speed.
Re: Mercedes fan upgrade [Re: hooziewhatsit] #838399
03/07/11 04:01 PM
03/07/11 04:01 PM
should not need the extra. fan apparenlty can take care of itself on that.
no control wire hooked up and it goes to full speed. you just need to control pulse to keep it at 90 percent so it doesn't burn out.
Re: Mercedes fan upgrade [Re: Andrewh] #838400
03/17/11 05:39 PM
03/17/11 05:39 PM
Alrighty, any other features I need to add? I'm almost done with the new version of the circuit board. I was hoping to be done with it a week ago but some stuff came up.
This version adds variable speed and the hardware to move the needle on the stock temp sensor. It will also bolt into the bigger white box using two standoffs in it (with two more sticky standoffs to support it).
I decided to remove the output to the dash status light. I really don't think I'll use it, nor would anyone else. I can hack one in later if someone really wants one.
Re: Mercedes fan upgrade [Re: feets] #838401
03/18/11 10:19 AM
03/18/11 10:19 AM
so, now you can
control the speed.
use either stock temp sensor or your aftermarket.
run the fan on or off, instead of speed control.
feed the stock gauge with a constant 5v vr for the gauges.
have a check for loss of temp sensor(either one?)
still need to confirm 90 percent driving either on/off or loss of temp sensor.
a/c signal
adjustible on by temp
anything I forgot?
Re: Mercedes fan upgrade [Re: Andrewh] #838402
03/18/11 02:42 PM
03/18/11 02:42 PM
so, now you can
control the speed.
a/c signal
anything I forgot?
I think you got everything
To clarify for others, "feed the stock gauge with a constant 5v vr for the gauges.", if you have a constant 5v reg in the cluster, I can vary the ground of the gauge to move the needle. The controller board itself does not provide the 5v.
I can detect a loss of either sensor and turn the fan on. I still have the dip switch to allow a relay or switch to turn the fan on.
Surprisingly, the added hardware for variable speed and to move the needle only added about $5 to the total cost.
I may be able to finish the design and send it off today, but with family coming tomorrow, I may need to wait until monday.
Re: Mercedes fan upgrade [Re: hooziewhatsit] #838403
03/18/11 03:29 PM
03/18/11 03:29 PM
cool. my big deal is still the 90 percent driver without the temp signal and if you lose the control line. but I suppose that is an odd occurence.
Re: Mercedes fan upgrade [Re: Andrewh] #838404
04/02/11 06:51 PM
04/02/11 06:51 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Do you have the variable fan controller ready to go?I'll be ready to ride in the next month.
Re: Mercedes fan upgrade [Re: gtx69] #838405
04/03/11 03:37 PM
04/03/11 03:37 PM
The circuit boards should show up on Tuesday (4/5). Another week or so to get the prototype going and another week or two for testing... I'd SWAG they should be ready in about a month
Re: Mercedes fan upgrade [Re: hooziewhatsit] #838406
04/03/11 05:56 PM
04/03/11 05:56 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Good news!
Now I can start working to convince you that updating the Auto Temp systems is in your best interest.
- Stu Harmon
Re: Mercedes fan upgrade [Re: feets] #838407
04/10/11 02:13 PM
04/10/11 02:13 PM
Good news!
Show me the market and all the specs, and I'll put it in line behind the fan controller, 46RE controller, and Andy's seat controller.
Got to the point I could test the fan this morning, and it seems to work just fine
With a 90% signal on the trigger line, and a signal on the speed line, it doesn't work as desired. With a speed signal, it appears to require a 100% signal on the trigger line. So if the fan suddenly goes to 100%, check the wiring to make sure everything is still connected.
I still need to test moving the needle with the new hardware, but otherwise, variable speed control works Now I just need to come up with the control loops to vary the speed according to temperature.
Re: Mercedes fan upgrade [Re: hooziewhatsit] #838408
04/15/11 10:14 AM
04/15/11 10:14 AM
gtx69 Offline
super gas
gtx69  Offline
super gas
Re: Mercedes fan upgrade [Re: gtx69] #838409
04/20/11 09:58 PM
04/20/11 09:58 PM
Welll... had another urgent project come up that took a good chunk of my time the last couple weeks. Good news is, if that project takes off, I can retire early and spend more time on fun stuff like this
Anywho, I have the new code more or less tested in Excel to vary the speed according to the current temperature.
Now I just need it to stop raining so I can install the fan, and/or, the seller would stop jerking us around so we can move to our new place that has a garage
Oh yea, the prototype hardware is mostly done, and can control the speed just fine
