Engine replacement question #837649
10/24/10 04:55 PM
10/24/10 04:55 PM
Iowa
3
318Bruiser Offline OP
Iowa
I had a used 5.9 put in place of my original engine in my 98 Ram a few weeks ago. On the replacement engine the idler and water pump pullies both had rust. Should I have assumed that the mechanic was going to replace them with the original ones or just leave the bad ones on to replace later? I am done with this mechanic because of other dealings or I would ask him about it.
Re: Engine replacement question [Re: 318Bruiser] #837650
10/24/10 05:09 PM
10/24/10 05:09 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Are you talking about surface rust on shiny contact area of pullies from donor engine sitting for a bit? If so that is usually left alone and it may accellerate belt wear a little.
Re: Engine replacement question [Re: 318Bruiser] #837651
10/24/10 05:11 PM
10/24/10 05:11 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Don't assume anything.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Engine replacement question [Re: MoparforLife] #837652
10/24/10 05:22 PM
10/24/10 05:22 PM
Iowa
3
Iowa
The pullies are pitted and have quarter size rust that is raised up enough to make the belt slip to one side and chirp loudly. It is from sitting. I don't normally assume but hearing nothing but good things and being a friend of my father's, I did. Never again though. Going outside now to change the water pump one.
