Page 2 of 5 1 2 3 4 5
Re: stock 400 build [Re: DaytonaTurbo] #835849
10/24/10 01:57 AM
10/24/10 01:57 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
What is a voodoo 60302? I know it's a cam, but what?
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: stock 400 build [Re: Junky] #835850
10/24/10 09:42 AM
10/24/10 09:42 AM
Central NC
gch Online content
gch  Online Content
Central NC
Lunati Voodoo cams.
Re: stock 400 build [Re: Junky] #835851
10/24/10 09:53 AM
10/24/10 09:53 AM
IL
71383beep Offline
71383beep  Offline
IL
I agree if the 452's are already cut then I say use em. Notice in my post I said in stock form standing side by side.
I could care less what ANY book says...especially if its from mopar performance. Most of there junk breaks while looking at it because their QC is a joke. The "book" also says stock 383's ran 10:1 compression which is also a bunch of bull. I will gladly line up my boat anchor equipped mild built 383 to a mild non decked 383 with OC heads ANY DAY. Books are meaningless to real world experience and I have been there with this issue. Label anything you want with your fart in the wind nonsense...compression does matter and there is a world of difference between 7.8:1 and 9.2:1.
IF the 452 heads are properly milled to basically a CC design then yes I agree the 452's are a better port design and therefore should make more power. This is rare though because it requires A lot of head work and also requires intake decking and different pushrods too. It is not the normal route for a cheap rebuild.
I don't hang onto any open chamber heads...unless I need to prop a door open or...anchor my boat!
'73 GK6 Challenger Rallye - 340 4-Speed
Re: stock 400 build [Re: 71383beep] #835852
10/24/10 11:43 AM
10/24/10 11:43 AM
Middle of A Field
O
OrangeProwler Offline
O
Middle of A Field
I have a 400 myself as of recent and I am wondering how the Small Summit Cam would work for off the line? I noticed 1500-5000 rpm range where the Lunati Voodoo 60301 is 1000-5500 rpm. I am going to running a stock bottom end since I'm mostly just a cruiser. I have a Summit Cam in my 318 and I am happy with it but, it is 1200-5200 for the powerband. Anyways, just thinking.
Re: stock 400 build [Re: gch] #835853
10/24/10 12:03 PM
10/24/10 12:03 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Lunati Voodoo cams.
I mean, what's the specs?
Re: stock 400 build [Re: Junky] #835854
10/24/10 12:22 PM
10/24/10 12:22 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
With those pistons still being a mile down in the holes it doesn't really matter what kinda lump of iron you put on there, it will still be a dog. In this stage I think compression ratio makes more power than headflow.
I agree with the '71bee here that in stock form I take a closed chamber head anytime over an open chamber smoghead. There's more than just this .5 point of compression gain. With proper 0-deck (dished) pistons there's also quench-effect to be achieved.
In true redneck style one could ofcourse put a .100" slab of JB weld on the pistons to increase the CR a bit...
Re: stock 400 build [Re: Junky] #835855
10/24/10 01:13 PM
10/24/10 01:13 PM
pana illinois
bigblock4x4 Offline OP
pana illinois
Lunati Voodoo cams.
it's 262/268,220/226@.050,.475/.494 with a 108 degree centerline,1400-5800rpm range
Re: stock 400 build [Re: bigblock4x4] #835856
10/24/10 01:20 PM
10/24/10 01:20 PM
St. John's Newfoundland
440newport Online content
440newport  Online Content
I added a 850 TQ, performer intake, Hp manifolds and a Lunati 60302 cam to a stock compression 74 400 2v and I'd say it "feels" like 300 horse or so now. Keep in mind it's in a 4500lb 73 New Yorker with 2.76 gears so it isn't quick but from a roll it moves ok for what it is.
When I had the heads off the pistons were about .090 in the hole.
Re: stock 400 build [Re: OrangeProwler] #835857
10/24/10 03:32 PM
10/24/10 03:32 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I bet for what you are doing, both cams would be pretty similar in performance. As far as operating rpm range listed, those numbers are arbitrary,i.e. they just pulled the numbers out of their azzez.
Re: stock 400 build [Re: forphorty] #835858
10/24/10 06:31 PM
10/24/10 06:31 PM
pana illinois
pana illinois
i am using a tm6 intake not what i stated earlier
Re: stock 400 build [Re: forphorty] #835859
10/24/10 09:34 PM
10/24/10 09:34 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
small summit cam would work fine.
Re: stock 400 build [Re: bigblock4x4] #835860
10/25/10 11:11 AM
10/25/10 11:11 AM
Central NC
gch Online content
gch  Online Content
Central NC
IT would'nt be my 3rd or 4th choice.
I understand running what you have but I would keep my eyes open for a used rpm,ch4b,or a street dominator.
Re: stock 400 build [Re: BigBlockMopar] #835861
10/25/10 01:23 PM
10/25/10 01:23 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
bumping from 8:1 to 9:1 leaving all other things constant will yield in about a 4% power increase. I had a 360 that calculated out to just under 8:1 that made very respectable power, enough to allow my 3900lb 5th ave keep up with a 5.7L chrysler 300hemiC from a 20mph roll....some home porting to the heads, headers, RPM air gap, and a comp XE262 made for a very strong low comp motor.
anyway, I'd run the 452's if they're ready to run and are truly 80cc.
cam, run the lunati voodoo 60302. it's actually a 112LSA on a 108 ICL, and the comp XE268 is a 110 LSA on a 106 LSA.
with your weight, stall and gearing, I'd install it as ground (108LSA), if it was a heavier car, lower stall, or taller gearing, I'd consider installing it advanced another 2-4 degrees (104-106 degree ICL.
intake, I'd probably run in this order: performer RPM, DP4B, street dominator, performer, M1 dual plane, weiand dual plane, stock manifold,
I'd definitely run headers, cheapest 20hp/20lb-ft torque you'll find.
2017 Grand Cherokee Overland
Re: stock 400 build [Re: patrick] #835862
10/25/10 01:52 PM
10/25/10 01:52 PM
Middle of A Field
O
O
Middle of A Field
I agree with patrick on the headers only because Comp Cams Program showed around the same gains going to small tube headers vs using HP log manifolds.
Re: stock 400 build [Re: OrangeProwler] #835863
10/25/10 01:53 PM
10/25/10 01:53 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
I wonder if the same would hold true with HP manifolds that have been cleaned up internally and port matched?
Earning every penny of that moderator paycheck.
DBAP
Re: stock 400 build [Re: not_a_charger] #835864
10/25/10 02:00 PM
10/25/10 02:00 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
w/ patrick on the intake manifold choices. With the voodoo 60302 being a mild cam and ground on a 112LSA, you wouldn't see a huge difference between hp manifolds and cheapie headers.
Re: stock 400 build [Re: not_a_charger] #835865
10/25/10 02:26 PM
10/25/10 02:26 PM
Middle of A Field
O
O
Middle of A Field
I would imagine if you had them extruded out a bit I would think there would be some marginal difference. I mean after there is guys in the FAST class that has some good tricks up their sleeve.
Re: stock 400 build [Re: OrangeProwler] #835866
10/25/10 02:31 PM
10/25/10 02:31 PM
What about the rest of the exhaust system on a mild 400 like this? Would going to 2.5 duals be a worthwhile investment instead of 2.25 duals?
DBAP
Re: stock 400 build [Re: not_a_charger] #835867
10/25/10 02:35 PM
10/25/10 02:35 PM
Manitoba, Canada
Manitoba, Canada
Depends. My car had a compression bent 2.25" exhaust system on it when I bought it and in places on the curves that thing necked down to 1.75" or less. To me that's not acceptable. But if your car has a mandrel bent 2.25" system on it, I would say just keep it. If your system needs replacing or you haven't bought yet, go with the 2.5".
Re: stock 400 build [Re: not_a_charger] #835868
10/25/10 02:38 PM
10/25/10 02:38 PM
Middle of A Field
O
O
Middle of A Field
Not sure if it would make a big difference. I mean I could see a slight difference. I know this talks about a Cheby but, here's a start.
http://www.streetrodding.com/%20forums.view/30348
