Page 1 of 7 1 2 3 4 5 6 7
1972 Charger SE Project by CDN72SE #834710
10/20/10 04:38 PM
10/20/10 04:38 PM
Oakville, Ontario, Canada
CDN72SE Offline OP
CDN72SE  Offline OP
Hi All, I figured I would record my restoration (it will move slowly) here as I spend a lot of time on the site reading and following others restorations. I am also on the 71-74 site. This is my Y8 1972 Dodge Charger SE Brougham (production date 7-71) that I purchased from Nigel at National Moparts it was a rust-free North Carolina car that was parked due to a bad transmission and brought to Canada. To keep it running and because it was also a 318 car I swapped in my old 318 & TorqueFlite 727 from my first SE and drove it for about 5 years. It was last registered and on the road in 1992. It's traveled with me from place to place waiting for a restoration. I guess it's time to track what I will be doing, I am not a mechanic (or a body guy) but I have enjoyed working on my cars since I was young. I learned a lot early on from not having a lot of money to pay someone else to do the work for me. Funny enough now in my 40s I still don’t have the money.
This is basically how I bought it in August of 1992, I put on my Western Turbine rims that I had on my previous SE. It did come with 14" Rallye's which I sold to a guy with a Challenger. Then I bought a set of 15x7 Rallyes from Motor City Originals. Shortly after getting it home I added the Year One front spoiler, I also added the dual cut-out exhaust rear valence from a '74, it was pretty rusted, I cleaned it up and painted it, thought it looked cool even though my exhaust was nowhere near the openings. I never would have thought that 17 years later there would be new ones being produced, thanks AMD.
I’m not sure on the colour, I could go original but I probably won’t. I’m just adding the parts to it that I like such as the Ramcharger hood, front & rear spoilers, buckets, console with shifter, R/T taillights, hood pins and a tachometer to replace the clock. As far as the engine I will probably go with a 360.
I'd love to hear any comments or suggestions guys/gals.
Those are P275/60R15's on the rear and up front P255/60R15's.
Rattle-can WAL-Mart black primer:
Yes it has the rear spoiler decklid cut-outs and yes it is the original '72 decklid.  :2thumbs:
Here she sits, March 2007 just after me moved to the new house, double-car garage... finally, now I'll have some room to work on it. Don't really have a budget, I'll probably fund some of it by selling some of my extra "back-up" pieces (yes still have a few). This will be a slow restoration that's for sure, I'll be doing as much as I can.
Removed the hood, decklid, fenders, doors, etc.
Not too bad behind the fenders:
Quite a bit of undercoating.
Some rear shots:
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #834711
10/20/10 04:40 PM
10/20/10 04:40 PM
CDN72SE Offline OP
CDN72SE  Offline OP
The car is pretty much fully covered with factory undercoating:
Couple of my 318 from my previous 72 that I installed in this car:
Rented an engine hoist from my local Stephenson's Rental, took me about two hours by myself (I did take my time) to get it out, as you can see I left the tranny attached and pulled it out as a unit. I had to let the air out of the two front tires to give me enough clearance over the radiator frame. Maybe I could have gone higher with the jack but was a bit fearful that my anchoring bolts on the engine may give way.
Transmission separated:
After 18 years the 318 is out again.
Rolled it outside, you definitely don't see anything like this in my neighbourhood.
Removed the torsion bars, wasn't as bad as I thought it would be, really had to whack them though.
Then I removed the 4 bolts for the K-Frame and dropped the whole assembly on to some blocks temporarily.
Here's the front suspension:
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #834712
10/20/10 04:48 PM
10/20/10 04:48 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Rallye Wheel Center Caps
Decided to do a little cleanup of some '71 Rallye Wheel centre caps (appliques) that I bought off eBay, I have seven in total some are the correct dark (charcoal) colour for '71 and some are the argent silver for 1970. I loosely followed an article that I have from a June 1991 Musclecar Review magazine. Materials I used include: Eastwood's Charcoal Rallye Wheel paint, 000-grade steel wool, chrome polish, 3M masking tape, and new rallye wheel center cap inserts. This is the procedure I followed:
1. Use a fine grade scuff pad like a 3M or Scotch to rough up the area which will allow the paint to adhere. Be sure to get into all the hard-to-reach areas, like lug nut holes.
2. Use the steel wool to to clean the unpainted chrome areas and use a polish to then polish those areas.
3. Mask off the clean chrome areas with 3M masking tape, leave some overhang and then trim off the pieces with a sharp knife or razor blade. Mask the back of the holes to prevent overspray.
4. Then paint the cap keeping the spray approx. 18-30 inches away, remember to turn the cap around a few times to get all the areas and 100% coverage.
Here is the finish product, with a fresh coat of paint and a new center cap insert which I purchased off eBay. I think they look good enough and I spent about 1.5hrs and less than $40. The taping and masking was the time consuming part.
Interior
I had removed the interior years ago, originally gold with a benchseat. I replaced the bench with one green and one white bucket seat that I had purchased and some panels from my previous SE that had the blue interior. Some of the panels I painted black (bad vinyl spray) and the back seat. I think I'm going to go with a white interior. Still debating the exterior colour.
Some more, I still have one of the Chrysler issued trash bags that came with the car. POR-15, peeled in a lot of places, yes I followed the directions, that was applied in 1992.
Back seat area:
Trunk:
More - really not bad, the trunk has some surface rust and all floorboards are pretty solid.
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #834713
10/20/10 04:50 PM
10/20/10 04:50 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Valances
That's the original '72 valance on the left and the one on the right is a '73 piece that I picked up NOS back in '92, I painted it in primer black and installed it on the car. It's still in excellent shape, but I'll be using the '72 (as everyone probably already knows they are different). The rear valance I had to buy, thought I'd better buy one just in case they decide to stop producing them.
Here is some evidence of where it was painted with some kind of black paint, even have the running paint to prove it. I often see a lot of these left body colour, maybe some are?
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #834714
10/20/10 04:51 PM
10/20/10 04:51 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Rear Brakes
Got out the wire brush and the rust encapsulator, these are 10" drums.
I had some red paint kicking around so used it on the drums as I'm using rallye's.
Think I had changed the rear shoes once since I've owned it, not sure if the hardware is original or not, I did order a kit.
Took care of the backing plates, one finished and one unfinished, I did the vinegar, lemon juice and salt method for removing rust on these. Did an excellent job.
I used some rust encapsulator, primer and then some of Eastwood's black steel rim paint that I have kicking around.
Got the wheel cylinder gaskets from DMT, the wheel cylinders from Canadian Tire and the riveted brake shoes from Napa.
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #834715
10/20/10 04:52 PM
10/20/10 04:52 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Headlight Buckets
Well I've got a few things on the go and trying not to get too far ahead of myself, been working on the rear leaf springs, rear brakes, heater box and headlight buckets. For now I'm concentrating on the headlight assembly and the heater box. So here are some pics of the start of my headlight and accessories re-fresh.
Drivers side fender with assembly attached:
Removed... not much to it, four bolts I'll bag those and clean them up later.
Took a bunch of shots of the position of everything for later:
Before cleaning, discovered the part numbers and paint marks, looks like we have red, orange and blue and I think black on the different cups, I have to record them:
Here's HI-LO-5-RT-.122 after a bath:
Here's one of the mounts after a little sanding and a few coats of Eastwood's Underhood Black Paint.
Next I'll finish cleaning the other parts, install the new headlight screws and hardware, reproduce the coloured stripes on the cups, polish the headlight rings and install the new sealed beams.
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #834716
10/20/10 04:55 PM
10/20/10 04:55 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Heater Box
Compared my original heater box to one I bought off eBay, hoping to make one out of the two, unfortunately the parts one got damaged during shipping. I should still be able to put the two together.
Original:
Donor:
What I'm working with:
Acouple more:
Last of the many pics I took:
Ordered a kit to do the rebuild, I'll update as I go along.
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #834717
10/20/10 04:57 PM
10/20/10 04:57 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Front Brakes & Components
Started to take apart the front brakes, I will clean up the calipers, maybe I'll rebuild them. Strip down the dust shields and paint them black as I do see that they had black paint on them. I bought new brake positioners and I have a pair of NOS hub grease caps.
Further taken apart:
Did a little painting:
More to come...
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #834718
10/20/10 04:58 PM
10/20/10 04:58 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Valances
That's the original '72 valance on the left and the one on the right is a '73 piece that I picked up NOS back in '92, I painted it in primer black and installed it on the car. It's still in excellent shape, but I'll be using the '72 (as everyone probably already knows they are different). The rear valance I had to buy, thought I'd better buy one just in case they decide to stop producing them .
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #834719
10/20/10 04:59 PM
10/20/10 04:59 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Crossmember
You can see how much undercoating I have on the bottom of this car, I plan on removing it. I guess some options are to just apply more undercoating over what's already there, leave it and patch or... what others have done use Lizardskin and re-cover the bottom. I have noticed in some spots where I have removed undercoating there is surface rust there so that leads me to believe that no everything is not going to be perfect underneath. I had gotten the car rustproofed over the years (Rustcheck) so I think that helped a lot and helped me dismantle the car with the basic tools I've always owned. I don't think I have ever broken a bolt.
The crossmember I'll de-grease and paint with Eastwood's Extreme Chassis Black. I bought a set of NOS crossmember bolts, they were cheap, mine were ok but all four were not the same. Does it make a difference? No, but hey they were NOS and now I can say I have some NOS parts.
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #834720
10/20/10 05:01 PM
10/20/10 05:01 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Ramcharger Setup
Well here's some of my Ramcharger parts, looks like I am missing one end cap or flapper or whatever you call it. Think I will be ordering one from PG Classics. I've bought many parts from them and the delivery is quick and the packaging is very good and oh yes the parts are nice as well.  :2thumbs:
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #834721
10/20/10 05:02 PM
10/20/10 05:02 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Undercoating & Removal
Well, on sunday I got my propane torch and putty knife and decided to start removing the undercoating, I am planning on replacing it at some point. The bottom of the car is starting off very easily, I think mainly because I used to get the car rustproofed so it's kind of supple. I haven't come across any rust yet, I know there is a little bit of surface rust where the gas tank resides, there was no undercoating there as the undercoating was applied after all the components were already on the car. Needed the torch on the stuff in the wheel wells and the front wheel well area. I almost regret removing it but I didn't want to take a chance of their being rust present.
Here are some before pictures showing how much coverage the car has.
Gas tank area with a little surface rust:
You can see the little patch that is missing and how clean it is underneath:
Here are some progress pics, nothing too exciting:
The whole floorpan basically looks like this, I was trying not to scratch it too much with the putty knife.
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #834722
10/20/10 05:05 PM
10/20/10 05:05 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Rear Axle & Differential
Thought I'd do a little cleaning of the axle, what a lot of caked on grease. I may replicate some of the paint daubs and markings not sure yet. Main goal is to strip it down, prime it and coat it with some of Eastwood's Extreme Chassis Black. With the differential I think I'll hit it with some Detail Gray.
Differential:
Started to do some detail of the rear.
Took care of the pinion snubber. De-greased it, soaked it in some Evaporust, primed it and then painted it.
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #834723
10/20/10 05:06 PM
10/20/10 05:06 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Brake Pedal
Here is my brake pedal assembly that I just finished freshening up. Did it over a few days as time permitted. Here it is as removed from the car.
Disassembled:
Gave this part a little bath in the vinegar, lemon juice and salt solution. For the rest I used Evaporust, for light stuff I used the red scotchbrite pad and/or steel wool.
Cleaned up and painted:
These pieces I left their natural colour and coated with some of Eastwood's clear.
Here is a before shot:
Some more:
another, painted the whole thing with Seymour Stainless Steel paint and then sprayed over most of it with Eastwood's Underhood Black. Mine originally faded from black paint to bare steel.
Here it is all back together, wasn't hard to do and I think I'll move on to the emergency brake next.
[img]https://farm5.staticflickr.com/4650/25358059067_87f38a779b_z.jpg[/img]
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #834724
10/20/10 09:41 PM
10/20/10 09:41 PM
An Island in the Pacific N.W.
moopa Offline
moopa  Offline
What a great job you are doing! Thanks for taking the time to do a step by step process with photos...alot of this info will help me with my Satellite.
Keep it up!
Mark
2015 TorRed Challenger Hellcat,A8 2013 Plum Crazy Challenger SRT8,6 Spd 2013 Black Challenger R/T Classic,auto (2)72 Satellites, one on hold,one under resto on the rotisserie.
Re: 1972 Charger SE Project by CDN72SE [Re: moopa] #834725
10/20/10 11:52 PM
10/20/10 11:52 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Thank you Mark, your comments are much appreciated.
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #834726
10/21/10 12:44 AM
10/21/10 12:44 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I really like your car and what you're doing with it. Keep up the good work.
Sheldon
Re: 1972 Charger SE Project by CDN72SE [Re: RUNCHARGER] #834727
10/21/10 12:48 AM
10/21/10 12:48 AM
CDN72SE Offline OP
CDN72SE  Offline OP
Thanks Sheldon.
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #834728
10/24/10 08:03 PM
10/24/10 08:03 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Just picked up one of the blemished Tuff repro wheels from Dale's Cuda Shop, it's the one on the left. Nice part.
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #834729
03/27/11 02:53 AM
03/27/11 02:53 AM
CDN72SE Offline OP
CDN72SE  Offline OP
Cleaned up and painted the Wheelhouse Vapor Canister & Shields.
Before:
After:
