Page 3 of 3 1 2 3
Re: Aftermarket AC in a non-air Cuda - THANKS BILL ALLPHIN [Re: PAINT IT BLACK] #834283
03/04/11 12:56 PM
03/04/11 12:56 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
That won't work. The drain is lower than the plate and you'll be working against gravity.
I thought about that after I hit post.
Another idea. Get some of the clear semi rigid tubing at a hardware store and run it under the carpet along the trans tunnel OR across the firewall then down the rocker panel, and then cut a hole in one of the floorpan body plugs.
You could duct tape it to the hump , that way it's not going to get pinched
Re: Aftermarket AC in a non-air Cuda - THANKS BILL ALLPHIN [Re: gtx6970] #834284
03/05/11 01:32 AM
03/05/11 01:32 AM
Houston Texas
PAINT IT BLACK Offline OP
Got a CHIP on my shoulder
Houston Texas
That may work... I'm going to get the car further along before I decide to tackle this. I'll post here again when I do.
Re: Aftermarket AC in a non-air Cuda - firewall pics? [Re: jbc426] #834285
07/08/12 12:09 AM
07/08/12 12:09 AM
WI
jphemi Offline
jphemi  Offline
WI
I was wondering if you had any pictures that show your a/c lines running from the "hidden a/c" compressor. I am trying to decide if I should buy Bouchillon's condensor package to connect to the "hidden a/c compressor along with their non-factory appearing condensor or try to piece something together.
Thanks.
Re: Aftermarket AC in a non-air Cuda - firewall pics? [Re: jphemi] #834286
07/31/12 04:48 AM
07/31/12 04:48 AM
north of detroit Michigan
Grimmey71 Offline
Grimmey71  Offline
Since I already finished my firewall and don't want to drill more holes than needed, do you guys who have done this think it would be possible to do a stud plate then use panel adhesive to glue the stud plate to the inside of the firewall?
Page 3 of 3 1 2 3
