Page 1 of 3 1 2 3
Aftermarket AC in a non-air Cuda - firewall pics? #834243
10/19/10 10:25 PM
10/19/10 10:25 PM
Houston Texas
PAINT IT BLACK Offline OP
Got a CHIP on my shoulder
Houston Texas
So I realize that the Vintage Air system eliminates the factory blower motor... what happens with the huge hole in the firewall??
Re: Aftermarket AC in a non-air Cuda - firewall pics? [Re: PAINT IT BLACK] #834244
10/19/10 10:45 PM
10/19/10 10:45 PM
Andrewh Online content
Andrewh  Online Content
both vintage and classic used to(not sure what they do now) provide a cover with a hole in it to route all the lines and hoses.
Re: Aftermarket AC in a non-air Cuda - firewall pics? [Re: Andrewh] #834245
10/19/10 11:39 PM
10/19/10 11:39 PM
Plainfield, Il.
cuda72 Offline
cuda72  Offline
Plainfield, Il.
I just bought the Vintage Air kit for my '72 Cuda and am in the process of installing it. Everything is included in the kit, all the way down to the extra crank pulley and belt. The only thing it looks like I'll need to buy is new heater hose and R134a freon.
To answer your question, the Vintage Air kit includes a large round plate that covers the hole in the firewall. This plate has four holes in it in which the two heater hoses and two freon lines enter.
Re: Aftermarket AC in a non-air Cuda - firewall pics? [Re: cuda72] #834246
10/20/10 12:38 AM
10/20/10 12:38 AM
Houston Texas
Houston Texas
That is exactly what I wanted to hear. I just restored my heater box, but I saw a Camaro today with the Vintage air system and I thought.... hmmmmm....that sure would be nice on a Houston summer day....
I think I'm gonna do it. I can probably sell my box/blower motor for nearly what it will cost to get the system. No brainer.
Re: Aftermarket AC in a non-air Cuda - firewall pics? [Re: cuda72] #834247
10/20/10 03:02 AM
10/20/10 03:02 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I just picked up a vintageair evaporator kit, but got the pump and condensor elsewhere. Purchased and hid the A/C pump using Bouchillion below the alternator kit and got the maximum sized condensor for my 26" radiator opening from Classicautoair for about 1/2 the cost of anywhere else.
I then put a couple of bulk packs of Dynamat extreme(1/2 price and free shipping from Amazon) and some aircraft insulation(http://www.aircraftspruce.com/catalog/appages/insulator.php) in the car where you won't be able to see it after the interior is in.
In fact, the whole A/C system will be hard to see once it's all in, even with the hood open. I figured it was a neccesity with a triple black color scheme.
Re: Aftermarket AC in a non-air Cuda - firewall pics? [Re: jbc426] #834248
10/20/10 11:17 AM
10/20/10 11:17 AM
Houston Texas
Houston Texas
I can't use the Bouchillion bracket... I have a small block with a mechanical fuel pump...
Re: Aftermarket AC in a non-air Cuda - firewall pics? [Re: PAINT IT BLACK] #834249
10/20/10 11:28 AM
10/20/10 11:28 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Steve,
I'm putting a Vintage air kit on a non air 1970 cuda now.
There is large ( about 8" ) plate that covers the original blower motor opening in the firewall. This plate is where the new a/c lines and heater core tubes now come thru the firewall.
The main problem I have is the Vintage air kit requires extra holes be drilled in the firewall, and they go thru right where the cowl seam is.
So, after talking to the cars owner, we decided to make new mouting brackets to mount the air box using the original heater box mounting points. Once we get this new plate cut and test fit I'll post an update
Re: Aftermarket AC in a non-air Cuda - firewall pics? [Re: gtx6970] #834250
10/20/10 11:36 AM
10/20/10 11:36 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I'm using the bouchillon compressor, kit and mounting brackets and pulleys.
My best advise, use the instructions as a guide, I ended up modifiy some(most) of the spacers to align all the pulleys .
It's on a Big stroker street Hemi with the factory 2 four intake. One of the customers requirements is it has to fit under the stock air cleaner, and so far so good.
ps- I'll be in touch soon for a custom AAR style hemi air cleaner as well.
Re: Aftermarket AC in a non-air Cuda - firewall pics? [Re: gtx6970] #834251
10/20/10 11:58 AM
10/20/10 11:58 AM
Houston Texas
Houston Texas
Steve,
Please do. I'd much rather not have to drill.
Re: Aftermarket AC in a non-air Cuda - firewall pics? [Re: gtx6970] #834252
10/20/10 12:01 PM
10/20/10 12:01 PM
Houston Texas
Houston Texas
That obviously was a major concern for me. I've got an AAR style base and need the clearance. But if people are using shaker bases, mine should fit as well.
Give me a ring on the customer's base when it comes time.
Re: Aftermarket AC in a non-air Cuda - firewall pics? [Re: PAINT IT BLACK] #834253
10/20/10 12:10 PM
10/20/10 12:10 PM
Cooperstown, NY
jrlegacy23 Offline
jrlegacy23  Offline
Cooperstown, NY
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
Re: Aftermarket AC in a non-air Cuda - firewall pics? [Re: PAINT IT BLACK] #834254
10/20/10 12:20 PM
10/20/10 12:20 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I'd like to see the no-drill adaptor too. Here's another shot of the hidden bracket kit with a shaker. The kit lined everything up with no modifications at all.
As it turns out, my power steering belt also goes around a second pulley on the water pump. It's always been like this since I got the car in 1978. According to all the manuals, it didn't come this way, but it sure looks and lines up like original. It not only keeps the water pump spinning in the event the main alternator belt breaks or gets thrown, but also counteracts the waterpump bearing wear from the alternator belt tension.
Re: Aftermarket AC in a non-air Cuda - firewall pics? [Re: jbc426] #834255
10/23/10 10:55 PM
10/23/10 10:55 PM
Plainfield, Il.
cuda72 Offline
cuda72  Offline
Plainfield, Il.
While working on the installation of the Vintage Air kit (and I'm sure it is the same with all brands), I found out the hard way that the dashboard will have to come out in order to get to the four screws that hold the factory defroster duct in place.
At first glance it seems like a simple matter of removing the four screws from the top of the defroster vent to remove the duct, but as it turns out the four screws that actually hold the duct in place are hidden behind the framework of the dash, and those four screws in the defroster opening are used to secure the dash near the windshield. So just be warned before starting...
Overall however, I couldn't be more pleased with the quality of this Vintage Air package. I've already mounted the compressor and condenser with no problems whatsoever, and was very surprised that everything fits perfectly so far.
As I progress, I'll keep posting status reports and things to watch out for when performing this type of installation.
Re: Aftermarket AC in a non-air Cuda - firewall pics? [Re: gtx6970] #834256
10/23/10 11:01 PM
10/23/10 11:01 PM
Plainfield, Il.
cuda72 Offline
cuda72  Offline
Plainfield, Il.
Steve,
If/when you come up with a suitable plate to mount the core without drilling extra hole in the firewall, please post some info or photos on the bracket so others (such as me ) don't have to reinvent the wheel
Re: Aftermarket AC in a non-air Cuda - firewall pics? [Re: cuda72] #834257
10/23/10 11:32 PM
10/23/10 11:32 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I'm installing an aftermarket kit in mine by nostalgic air. I decided to weld closed the original hole for the blower motor. This way I can route the hoses through where I want them. But for those who have a high $ car and/or don't want to modify, the block off plates for the blower motor hole look decent on cars I've seen them on.
Re: Aftermarket AC in a non-air Cuda - firewall pics? [Re: cuda72] #834258
10/24/10 11:45 AM
10/24/10 11:45 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Steve,
Will do, I have the basic plate cut now.
I have to do some final trimming tomorrow( I may do it today) and make any adjustments .
It's basically just a flat plate with a re-inforcement rib along the top to prevent oil-canning and add some ridgity to the plate.
With no issues , the A/C box goes in the 1st of the week
I'll be making a last minute run to florida for a funeral, I'm guessing mid-week. So not much is going to get done this week.
Re: Aftermarket AC in a non-air Cuda - firewall pics? [Re: gtx6970] #834259
10/26/10 09:29 AM
10/26/10 09:29 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Ok, here is the test shot of the plate.
It was cut in stainless( material was free) but isn't required. You should put some kind of stiffening rib in it to prevent it from bowing
Re: Aftermarket AC in a non-air Cuda - firewall pics? [Re: gtx6970] #834260
10/26/10 09:31 AM
10/26/10 09:31 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
The plate then attaches to the kit supplied box mounting brackets the same way as if attaching to the cars firewall as shown.
Re: Aftermarket AC in a non-air Cuda - firewall pics? [Re: gtx6970] #834261
10/26/10 09:32 AM
10/26/10 09:32 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
view from the opposite side
Re: Aftermarket AC in a non-air Cuda - firewall pics? [Re: gtx6970] #834262
10/26/10 09:33 AM
10/26/10 09:33 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
another view - same side
In this view you can see I added a second round bulkhead plate to add strength and rigidity to my plate. You may or may not need this depending on the gauge of your custom bracket.
The kit comes with only one of the round bulkhead plates and it's on the engine compartment side of the firewall
Page 1 of 3 1 2 3
