Re: ? body in white program ?
[Re: a12superbee]
#83385
07/18/08 07:35 AM
07/18/08 07:35 AM
Posts: 761 Raleigh, NC
John426
super gas
super gas
Raleigh, NC
Just to clarify, this car will only cost 17500 to get back to a usable, stable, clean shell? If so, I think you'll be getting some calls shortly.
This one did need a roof and frame rails, which are extra. We found a complete front clip for $600, have a new roof skin and will be using brand new frame rails in the rear. With all the extras this one will still be under $20K.
[Re: cataclysm80]
#83387
07/18/08 04:20 PM
07/18/08 04:20 PM
#83388
07/18/08 08:42 PM
07/18/08 08:42 PM
do u guys pick the cars up and drop them off when there done??? and about how long does it take????
#83392
07/19/08 09:38 AM
07/19/08 09:38 AM
John426
super gas
super gas
Raleigh, NC
We do pickup and deliver. We have an 24' enclosed trailer, an open trailer and a Dodge Ram Diesel. We only provide pickup / dropoff for customers. Cost hovers around $1.00 per mile, based on fuel costs mostly these days (smile).
Once we have the car back from being stripped and the parts in hand, about 30 days turn around. The stripper can be 6-8 weeks depending on workload and some parts can be hard to source, so plan accordingly!
Keep an eye on the 1970 Challenger RT / SE - we just received the last of the sheetmetal we needed and started seriously working on the car on July 11, it is almost completely disassembled on July 18 and starts being reassembled late next week.
We are also working on an 'ala carte' menu of panel replacement for folks that do not need or want the entire body in white program. Say you just want a trunk floor and drop offs replaced, we'll be able to have a set price for replacing those pieces.
[Re: anlauto]
#83393
07/19/08 11:15 AM
07/19/08 11:15 AM
Posts: 636 California
sixpaktoogo
California
What kind of jig do you use to put it together?
And the answer is?????
[Re: sixpaktoogo]
#83394
07/19/08 12:25 PM
07/19/08 12:25 PM
John426
super gas
super gas
Raleigh, NC
It sounds like a simple enough question, but at the detail level, its complicated. There is no single 'jig' to reassemble a mopar. We use a combination of square and level assemblies (similar in concept to a surface plate you would find in a NASCAR cup fab shop) combined with trammel bars and a lot of measurements.
A lot of the small assemblies (bracket location etc.) might have been jigged at the factory, but its just not practical to build a jig to assemble a small number of cars a year. I would need another storage facility just for all the jigs!)
I think (doing this from memory at home today) that section 23 of the Factory Service Manual is the body section - there are measurements in the manual that call out all the various diagonals and heights etc. for the Mopar unibodies. Those are the "gospel" measurements we use to verify final alignment and fitment.
So the short answer would be; shop made jigs and fixtures together with trammel bars and a lot of measuring - I'm unaware of anything else!!
[Re: John426]
#83395
07/19/08 01:48 PM
07/19/08 01:48 PM
Posts: 901 Williamsport, PA
Kingy
Royal Pain
Royal Pain
Williamsport, PA
Ain't that the truth!
[Re: sixpaktoogo]
#83396
07/19/08 03:19 PM
07/19/08 03:19 PM
His answer below is the correct way to repair a unibody. Body shops were of course never expected to have jigs for cars and this is why the factories developed a measurement system for key points on the unibodies, to make sure they were repaired properly without any weak points in the structure, to keep them from folding up on impact.
These measurements are still used today and laser measuring equipment has been arount for at least 20 years for this purpose. In the old days you sometimes had to use string.
