Re: Using Rust Mort??
[Re: DusterKrazy]
#830855
10/17/10 03:38 PM
10/17/10 03:38 PM
Posts: 1,601 Hatfield,Pa.
bigD
Hatfield,Pa.
When I used it on my dart, I would try to get the area as clean as possible (bare metal), put the rust mort on let it set but not dry and then wipe down with water to stop the etching process. A quick wipe down with IPA and then acetone and then its ready for a skim coat of filler/sanding /priming,D.
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
